[postgis-tickets] [PostGIS] #2503: ERROR: table "topology" is not a member of the extension being created
PostGIS trac at osgeo.org
Mon Oct 15 22:12:03 PDT 2018
  Reporter:  strk                   |      Owner:  robe
      Type:  defect                 |     Status:  reopened
  Priority:  blocker                |  Milestone:  PostGIS 2.1.1
 Component:  build/upgrade/install  |    Version:  trunk
Resolution:                         |   Keywords:  extension
Comment (by strk):
 So, the other fix is moving the pg_catalog.pg_extension_config_dump dumps
 to _AFTER_ the corresponding tables were added to the extension. Right now
 those calls are part of the extension upgrade scripts (--ANY--
 3.0.0dev.sql) so they happen _before_.
 I don't know why we use the extension upgrade scripts rather than the
 normal upgrade scripts for the pre-packaging upgrade, I think it is wrong.
 Will try using the normal (script-based) upgrade script instead
Ticket URL: <https://trac.osgeo.org/postgis/ticket/2503#comment:23>
