[postgis-tickets] [PostGIS] #2503: ERROR: table "topology" is not a member of the extension being created
PostGIS trac at osgeo.org
Wed Oct 17 01:32:43 PDT 2018
  Reporter:  strk                   |      Owner:  robe
      Type:  defect                 |     Status:  reopened
  Priority:  blocker                |  Milestone:  PostGIS 2.1.1
 Component:  build/upgrade/install  |    Version:  trunk
Resolution:                         |   Keywords:  extension
Comment (by strk):
 Yes, run_test.pl accepts a --dumprestore switch.
 Winnie, Debbie and GitLab-CI seem to be passing that
 switch via RUNTESTFLAGS on "make check" so they must
 be also including topology
Ticket URL: <https://trac.osgeo.org/postgis/ticket/2503#comment:27>
