[postgis-tickets] [PostGIS] #4206: "getrelid" removed in PostgreSQL v12devel
PostGIS trac at osgeo.org
Wed Oct 17 06:55:15 PDT 2018
  Reporter:  Laurenz Albe           |      Owner:  strk
      Type:  patch                  |     Status:  new
  Priority:  medium                 |  Milestone:  PostGIS 3.0.0
 Component:  build/upgrade/install  |    Version:  trunk
Resolution:                         |   Keywords:  getrelid
Comment (by strk):
 I suggest you keep the getrelid and use a macro which either
 calls "getrelid" or "rt_fetch" based on what's available
 based on PG_VERSION_NUM
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4206#comment:2>
