[postgis-tickets] [PostGIS] #4206: "getrelid" removed in PostgreSQL v12devel
PostGIS trac at osgeo.org
Wed Oct 17 07:28:41 PDT 2018
  Reporter:  Laurenz Albe           |      Owner:  strk
      Type:  patch                  |     Status:  closed
  Priority:  medium                 |  Milestone:  PostGIS 3.0.0
 Component:  build/upgrade/install  |    Version:  trunk
Resolution:  fixed                  |   Keywords:  getrelid
Changes (by strk):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"16921" 16921]:
 #!CommitTicketReference repository="" revision="16921"
 Fix support for PostgreSQL-12 ("getrelid" macro removed)
 The call is replaced with its expansion which should work
 as back as PostgreSQL-9.1 which is before the oldest version
 PostGIS-2.2 (our oldest maintained branch) supports.
 This is then safe to backport to all branches till 2.2.
 Patch by Laurenz Albe
 Closes #4206 in 2.2 branch
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4206#comment:6>
