[postgis-tickets] [PostGIS] #4209: Issues using pgsql2shp with a postgis table with null geometries
PostGIS trac at osgeo.org
Fri Oct 19 07:44:08 PDT 2018
 Reporter:  gabrimonfa  |      Owner:  pramsey
     Type:  defect      |     Status:  new
 Priority:  medium      |  Milestone:
Component:  postgis     |    Version:  trunk
 Keywords:              |
 The table has 7120 rows, 50 have null geometries and some of them are at
 the beginning of the table.
 Server is PostgreSQL 9.5 with postgis version "2.2 USE_GEOS=1 USE_PROJ=1
 USE_STATS=1".
 == Desired behaviour
 The shape is created with all the rows, null geometries in the table are
 null geometries in the shapefile.\\
 Or it would be possible to add a null handling policy as in shp2pgsql.\\
 == Actual behaviour
 **pgsql2shp 2.4.4** (ubuntu 18.10 package)\\
 The exported shapefile has 7070 rows (as the number of rows with not null
 geometry in original table), but apparently they are the ''first'' 7070
 rows, some rows with not null geometry are missing.\\
 All is working correctly if I use a "where geom is not null" clause.
 **pgsql2shp 2.5.0** (package from apt.postgresql.org in ubuntu 18.04)\\
 Segmentation fault\\
 **pgsql2shp 3.0.0 trunk from svn**\\
 Program received signal SIGSEGV, Segmentation fault.
 geometry_type_from_string (str=0x5555557d21f8 "",
 type=type at entry=0x7fffffffd9bb "", z=z at entry=0x7fffffffd9bc,
 m=m at entry=0x7fffffffd9bc) at g_util.c:203
 203                     tmpstr[i - tmpstartpos] = dump_toupper(str[i]);
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4209>
