[postgis-tickets] [PostGIS] #4200: move core regress tests under regress/core
PostGIS trac at osgeo.org
Fri Oct 19 16:06:32 PDT 2018
  Reporter:  strk                   |      Owner:  strk
      Type:  enhancement            |     Status:  closed
  Priority:  medium                 |  Milestone:  PostGIS 3.0.0
 Component:  build/upgrade/install  |    Version:  trunk
Resolution:  fixed                  |   Keywords:
Changes (by strk):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"16929" 16929]:
 #!CommitTicketReference repository="" revision="16929"
 Split core and sfcgal tests allowing to run one w/out the other
 Closes #4200
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4200#comment:2>
