[postgis-tickets] r16932 - Fix SFCGAL tests
Sandro Santilli strk at kbt.io
Sun Oct 21 03:19:25 PDT 2018
Author: strk
Date: 2018-10-21 03:19:25 -0700 (Sun, 21 Oct 2018)
New Revision: 16932
Added:
   trunk/regress/sfcgal/regress_sfcgal.sql
   trunk/regress/sfcgal/regress_sfcgal_expected
Removed:
   trunk/regress/core/regress_sfcgal.sql
   trunk/regress/core/regress_sfcgal_expected
   trunk/regress/sfcgal/Makefile.in
   trunk/regress/sfcgal/concave_hull.sql
   trunk/regress/sfcgal/legacy.sql
   trunk/regress/sfcgal/regress.sql
   trunk/regress/sfcgal/regress_ogc.sql
Fix SFCGAL tests
Deleted: trunk/regress/core/regress_sfcgal.sql
--- trunk/regress/core/regress_sfcgal.sql	2018-10-21 09:59:48 UTC (rev 16931)
+++ trunk/regress/core/regress_sfcgal.sql	2018-10-21 10:19:25 UTC (rev 16932)
@@ -1,41 +0,0 @@
---- Regression tests for PostGIS SFCGAL backend
--- We only care about testing PostGIS prototype here
--- Behaviour is already handled by SFCGAL own tests
-SELECT 'postgis_sfcgal_version', count(*) FROM (SELECT postgis_sfcgal_version()) AS f;
-SELECT 'ST_Tesselate', ST_AsText(ST_Tesselate('GEOMETRYCOLLECTION(POINT(4 4),POLYGON((0 0,1 0,1 1,0 1,0 0)))'));
-SELECT 'ST_3DArea', ST_3DArea('POLYGON((0 0 0,1 0 0,1 1 0,0 1 0,0 0 0))');
-SELECT 'ST_Extrude_point', ST_AsText(ST_Extrude('POINT(0 0)', 1, 0, 0));
-SELECT 'ST_Extrude_line', ST_AsText(ST_Extrude(ST_Extrude('POINT(0 0)', 1, 0, 0), 0, 1, 0));
--- In the first SFCGAL versions, the extruded face was wrongly oriented
--- we change the extrusion result to match the original
-SELECT 'ST_Extrude_surface',
-CASE WHEN postgis_sfcgal_version() = '1.0'
-THEN
-    ST_AsText(ST_Extrude(ST_Extrude(ST_Extrude('POINT(0 0)', 1, 0, 0), 0, 1, 0), 0, 0, 1))
-ELSE
-    regexp_replace(
-    regexp_replace(
-    ST_AsText(ST_Extrude(ST_Extrude(ST_Extrude('POINT(0 0)', 1, 0, 0), 0, 1, 0), 0, 0, 1)) ,
-    '\(\(0 1 0,1 1 0,1 0 0,0 1 0\)\)', '((1 1 0,1 0 0,0 1 0,1 1 0))'),
-    '\(\(0 1 0,1 0 0,0 0 0,0 1 0\)\)', '((1 0 0,0 0 0,0 1 0,1 0 0))')
-END;
-SELECT 'ST_ForceLHR', ST_AsText(ST_ForceLHR('POLYGON((0 0,0 1,1 1,1 0,0 0))'));
-SELECT 'ST_Orientation_1', ST_Orientation(ST_ForceLHR('POLYGON((0 0,0 1,1 1,1 0,0 0))'));
-SELECT 'ST_Orientation_2', ST_Orientation(ST_ForceRHR('POLYGON((0 0,0 1,1 1,1 0,0 0))'));
-SELECT 'ST_MinkowskiSum', ST_AsText(ST_MinkowskiSum('LINESTRING(0 0,4 0)','POLYGON((0 0,1 0,1 1,0 1,0 0))'));
-SELECT 'ST_StraightSkeleton', ST_AsText(ST_StraightSkeleton('POLYGON((1 1,2 1,2 2,1 2,1 1))'));
--- Backend switch tests
-SET postgis.backend = 'geos';
-SELECT 'intersection_geos', ST_astext(ST_intersection('LINESTRING(0 10, 0 -10)', 'LINESTRING(0 0, 1 1)'));
-SET postgis.backend = 'sfcgal';
-SELECT 'intersection_sfcgal', ST_astext(ST_intersection('LINESTRING(0 10, 0 -10)', 'LINESTRING(0 0, 1 1)'));
-SET postgis.backend = 'foo';
-SET postgis.backend = '';
Deleted: trunk/regress/core/regress_sfcgal_expected
--- trunk/regress/core/regress_sfcgal_expected	2018-10-21 09:59:48 UTC (rev 16931)
+++ trunk/regress/core/regress_sfcgal_expected	2018-10-21 10:19:25 UTC (rev 16932)
@@ -1,15 +0,0 @@
-postgis_sfcgal_version|1
-ST_Tesselate|GEOMETRYCOLLECTION(POINT(4 4),TIN(((0 1,1 0,1 1,0 1)),((0 1,0 0,1 0,0 1))))
-ST_3DArea|1
-ST_Extrude_point|LINESTRING Z (0 0 0,1 0 0)
-ST_Extrude_line|POLYHEDRALSURFACE Z (((0 0 0,1 0 0,1 1 0,0 1 0,0 0 0)))
-ST_Extrude_surface|POLYHEDRALSURFACE Z (((1 1 0,1 0 0,0 1 0,1 1 0)),((0 1 1,1 0 1,1 1 1,0 1 1)),((1 0 0,0 0 0,0 1 0,1 0 0)),((0 1 1,0 0 1,1 0 1,0 1 1)),((1 0 0,1 1 0,1 1 1,1 0 1,1 0 0)),((1 1 0,0 1 0,0 1 1,1 1 1,1 1 0)),((0 1 0,0 0 0,0 0 1,0 1 1,0 1 0)),((0 0 0,1 0 0,1 0 1,0 0 1,0 0 0)))
-ST_ForceLHR|POLYGON((0 0,1 0,1 1,0 1,0 0))
-ST_Orientation_1|-1
-ST_Orientation_2|1
-ST_MinkowskiSum|MULTIPOLYGON(((0 0,1 0,5 0,5 1,4 1,0 1,0 0)))
-ST_StraightSkeleton|MULTILINESTRING((1 1,1.5 1.5),(2 1,1.5 1.5),(2 2,1.5 1.5),(1 2,1.5 1.5))
-intersection_geos|POINT(0 0)
-intersection_sfcgal|POINT(0 0)
-ERROR:  Can't find foo geometry backend
-ERROR:  Can't find  geometry backend
Modified: trunk/regress/sfcgal/Makefile.in
--- trunk/regress/sfcgal/Makefile.in	2018-10-21 09:59:48 UTC (rev 16931)
+++ trunk/regress/sfcgal/Makefile.in	2018-10-21 10:19:25 UTC (rev 16932)
@@ -36,17 +36,17 @@
 	# SFCGAL additionnal backend
 	TESTS += \
 		regress_sfcgal \
-		sfcgal/empty.sql \
-		sfcgal/geography.sql \
-		sfcgal/legacy.sql \
-		sfcgal/measures.sql \
-		sfcgal/regress_ogc_prep.sql \
-		sfcgal/regress_ogc.sql \
-		sfcgal/regress.sql \
-		sfcgal/tickets.sql \
-		sfcgal/concave_hull.sql \
-		sfcgal/wmsservers.sql \
-		sfcgal/approximatemedialaxis.sql
+		empty.sql \
+		geography.sql \
+		legacy.sql \
+		measures.sql \
+		regress_ogc_prep.sql \
+		regress_ogc.sql \
+		regress.sql \
+		tickets.sql \
+		concave_hull.sql \
+		wmsservers.sql \
+		approximatemedialaxis.sql
 	SFCGALTESTFLAGS = --sfcgal
 endif
Modified: trunk/regress/sfcgal/concave_hull.sql
--- trunk/regress/sfcgal/concave_hull.sql	2018-10-21 09:59:48 UTC (rev 16931)
+++ trunk/regress/sfcgal/concave_hull.sql	2018-10-21 10:19:25 UTC (rev 16932)
@@ -1,9 +1,9 @@
---- SFCGAL backend tests based on GEOS/JTS implemented functions
-\cd :regdir
-\i concave_hull.sql
\ No newline at end of file
+--- SFCGAL backend tests based on GEOS/JTS implemented functions
+SET postgis.backend = 'sfcgal';
+\cd :regdir
+\i core/concave_hull.sql
Modified: trunk/regress/sfcgal/legacy.sql
--- trunk/regress/sfcgal/legacy.sql	2018-10-21 09:59:48 UTC (rev 16931)
+++ trunk/regress/sfcgal/legacy.sql	2018-10-21 10:19:25 UTC (rev 16932)
@@ -9,4 +9,4 @@
 \cd :regdir
-\i legacy.sql
+\i core/legacy.sql
Modified: trunk/regress/sfcgal/regress.sql
--- trunk/regress/sfcgal/regress.sql	2018-10-21 09:59:48 UTC (rev 16931)
+++ trunk/regress/sfcgal/regress.sql	2018-10-21 10:19:25 UTC (rev 16932)
@@ -191,7 +191,7 @@
 -- create a table with data that will be TOASTed (even after compression)
 create table TEST(a GEOMETRY, b GEOMETRY);
-\i regress_biginsert.sql
+\i :regdir/core/regress_biginsert.sql
 ---test basic ops on this
Modified: trunk/regress/sfcgal/regress_ogc.sql
--- trunk/regress/sfcgal/regress_ogc.sql	2018-10-21 09:59:48 UTC (rev 16931)
+++ trunk/regress/sfcgal/regress_ogc.sql	2018-10-21 10:19:25 UTC (rev 16932)
@@ -6,4 +6,4 @@
 \cd :regdir
-\i regress_ogc.sql
+\i core/regress_ogc.sql
Copied: trunk/regress/sfcgal/regress_sfcgal.sql (from rev 16931, trunk/regress/core/regress_sfcgal.sql)
--- trunk/regress/sfcgal/regress_sfcgal.sql	                        (rev 0)
+++ trunk/regress/sfcgal/regress_sfcgal.sql	2018-10-21 10:19:25 UTC (rev 16932)
@@ -0,0 +1,41 @@
+--- Regression tests for PostGIS SFCGAL backend
+-- We only care about testing PostGIS prototype here
+-- Behaviour is already handled by SFCGAL own tests
+SELECT 'postgis_sfcgal_version', count(*) FROM (SELECT postgis_sfcgal_version()) AS f;
+SELECT 'ST_Tesselate', ST_AsText(ST_Tesselate('GEOMETRYCOLLECTION(POINT(4 4),POLYGON((0 0,1 0,1 1,0 1,0 0)))'));
+SELECT 'ST_3DArea', ST_3DArea('POLYGON((0 0 0,1 0 0,1 1 0,0 1 0,0 0 0))');
+SELECT 'ST_Extrude_point', ST_AsText(ST_Extrude('POINT(0 0)', 1, 0, 0));
+SELECT 'ST_Extrude_line', ST_AsText(ST_Extrude(ST_Extrude('POINT(0 0)', 1, 0, 0), 0, 1, 0));
+-- In the first SFCGAL versions, the extruded face was wrongly oriented
+-- we change the extrusion result to match the original
+SELECT 'ST_Extrude_surface',
+CASE WHEN postgis_sfcgal_version() = '1.0'
+THEN
+    ST_AsText(ST_Extrude(ST_Extrude(ST_Extrude('POINT(0 0)', 1, 0, 0), 0, 1, 0), 0, 0, 1))
+ELSE
+    regexp_replace(
+    regexp_replace(
+    ST_AsText(ST_Extrude(ST_Extrude(ST_Extrude('POINT(0 0)', 1, 0, 0), 0, 1, 0), 0, 0, 1)) ,
+    '\(\(0 1 0,1 1 0,1 0 0,0 1 0\)\)', '((1 1 0,1 0 0,0 1 0,1 1 0))'),
+    '\(\(0 1 0,1 0 0,0 0 0,0 1 0\)\)', '((1 0 0,0 0 0,0 1 0,1 0 0))')
+END;
+SELECT 'ST_ForceLHR', ST_AsText(ST_ForceLHR('POLYGON((0 0,0 1,1 1,1 0,0 0))'));
+SELECT 'ST_Orientation_1', ST_Orientation(ST_ForceLHR('POLYGON((0 0,0 1,1 1,1 0,0 0))'));
+SELECT 'ST_Orientation_2', ST_Orientation(ST_ForceRHR('POLYGON((0 0,0 1,1 1,1 0,0 0))'));
+SELECT 'ST_MinkowskiSum', ST_AsText(ST_MinkowskiSum('LINESTRING(0 0,4 0)','POLYGON((0 0,1 0,1 1,0 1,0 0))'));
+SELECT 'ST_StraightSkeleton', ST_AsText(ST_StraightSkeleton('POLYGON((1 1,2 1,2 2,1 2,1 1))'));
+-- Backend switch tests
+SET postgis.backend = 'geos';
+SELECT 'intersection_geos', ST_astext(ST_intersection('LINESTRING(0 10, 0 -10)', 'LINESTRING(0 0, 1 1)'));
+SELECT 'intersection_sfcgal', ST_astext(ST_intersection('LINESTRING(0 10, 0 -10)', 'LINESTRING(0 0, 1 1)'));
+SET postgis.backend = 'foo';
+SET postgis.backend = '';
Copied: trunk/regress/sfcgal/regress_sfcgal_expected (from rev 16931, trunk/regress/core/regress_sfcgal_expected)
--- trunk/regress/sfcgal/regress_sfcgal_expected	                        (rev 0)
+++ trunk/regress/sfcgal/regress_sfcgal_expected	2018-10-21 10:19:25 UTC (rev 16932)
@@ -0,0 +1,15 @@
+postgis_sfcgal_version|1
+ST_Tesselate|GEOMETRYCOLLECTION(POINT(4 4),TIN(((0 1,1 0,1 1,0 1)),((0 1,0 0,1 0,0 1))))
+ST_3DArea|1
+ST_Extrude_point|LINESTRING Z (0 0 0,1 0 0)
+ST_Extrude_line|POLYHEDRALSURFACE Z (((0 0 0,1 0 0,1 1 0,0 1 0,0 0 0)))
+ST_Extrude_surface|POLYHEDRALSURFACE Z (((1 1 0,1 0 0,0 1 0,1 1 0)),((0 1 1,1 0 1,1 1 1,0 1 1)),((1 0 0,0 0 0,0 1 0,1 0 0)),((0 1 1,0 0 1,1 0 1,0 1 1)),((1 0 0,1 1 0,1 1 1,1 0 1,1 0 0)),((1 1 0,0 1 0,0 1 1,1 1 1,1 1 0)),((0 1 0,0 0 0,0 0 1,0 1 1,0 1 0)),((0 0 0,1 0 0,1 0 1,0 0 1,0 0 0)))
+ST_ForceLHR|POLYGON((0 0,1 0,1 1,0 1,0 0))
+ST_Orientation_1|-1
+ST_Orientation_2|1
+ST_MinkowskiSum|MULTIPOLYGON(((0 0,1 0,5 0,5 1,4 1,0 1,0 0)))
+ST_StraightSkeleton|MULTILINESTRING((1 1,1.5 1.5),(2 1,1.5 1.5),(2 2,1.5 1.5),(1 2,1.5 1.5))
+intersection_geos|POINT(0 0)
+intersection_sfcgal|POINT(0 0)
+ERROR:  Can't find foo geometry backend
+ERROR:  Can't find  geometry backend
