[postgis-tickets] r16934 - Avoid running core and sfcgal regress tests in parallel
Sandro Santilli strk at kbt.io
Sun Oct 21 11:36:37 PDT 2018
Author: strk
Date: 2018-10-21 23:36:37 -0700 (Sun, 21 Oct 2018)
New Revision: 16934
   trunk/regress/Makefile.in
... the alternative would be using different databases but lets
change things incrementally ...
Modified: trunk/regress/Makefile.in
--- trunk/regress/Makefile.in	2018-10-22 06:23:34 UTC (rev 16933)
+++ trunk/regress/Makefile.in	2018-10-22 06:36:37 UTC (rev 16934)
@@ -24,18 +24,12 @@
 all:
-check: staged-install check-core
+check: staged-install
+	$(MAKE) -C core check
 ifeq ($(HAVE_SFCGAL),yes)
-check: check-sfcgal
+	$(MAKE) -C sfcgal check
 endif
-check-core:
-	$(MAKE) -C core check
-check-sfcgal:
-	$(MAKE) -C sfcgal check
 clean:
 	$(MAKE) -C core $@
 	$(MAKE) -C sfcgal $@
