[postgis-tickets] r16936 - Fix support for overriding RUNTESTFLAGS via env variable
Sandro Santilli strk at kbt.io
Mon Oct 22 01:02:50 PDT 2018
Author: strk
Date: 2018-10-22 01:02:50 -0700 (Mon, 22 Oct 2018)
New Revision: 16936
   trunk/regress/sfcgal/Makefile.in
otherwise --sfcgal gets missing
Modified: trunk/regress/sfcgal/Makefile.in
--- trunk/regress/sfcgal/Makefile.in	2018-10-22 06:36:43 UTC (rev 16935)
+++ trunk/regress/sfcgal/Makefile.in	2018-10-22 08:02:50 UTC (rev 16936)
@@ -45,13 +45,11 @@
 		wmsservers.sql \
 		approximatemedialaxis.sql
-RUNTESTFLAGS += --sfcgal
 test check:
-	$(PERL) ../run_test.pl $(RUNTESTFLAGS) $(TESTS)
+	$(PERL) ../run_test.pl --sfcgal $(RUNTESTFLAGS) $(TESTS)
 	# only run upgrade test if RUNTESTFLAGS was not already doing that
 	if echo "$(RUNTESTFLAGS)" | grep -vq -- --upgrade; then \
-		$(PERL) ../run_test.pl --upgrade $(RUNTESTFLAGS) $(TESTS); \
+		$(PERL) ../run_test.pl --sfcgal --upgrade $(RUNTESTFLAGS) $(TESTS); \
 	fi
 else
