[postgis-tickets] [PostGIS] #4211: ST_Subdivide() on geometries with rings
PostGIS trac at osgeo.org
Mon Oct 22 03:38:54 PDT 2018
  Reporter:  morena   |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 2.5.1
 Component:  postgis  |    Version:  2.5.x
Resolution:           |   Keywords:  ST_Subdivide
Comment (by komzpa):
 Cannot reproduce.
 Result I get:
 POLYGON((-88.2059 41.7325,-88.206 41.7244,-88.1959 41.7241,-88.1959
 41.7326,-88.2059 41.7325),(-88.1997 41.7289,-88.1996 41.7285,-88.199
 41.7285,-88.199 41.7289,-88.1997 41.7289))
 is expected, as your geometry is already below default 256 points. What
 are you using for rendering? May it happen interior ring is lost somewhere
 else in the process?
  POSTGIS="2.5.0 r16836" [EXTENSION] PGSQL="110" GEOS="3.6.2-CAPI-1.10.2
 4d2925d6" PROJ="Rel. 5.1.0, June 1st, 2018" GDAL="GDAL 2.3.2, released
 2018/09/21" LIBXML="2.9.4" LIBJSON="0.12.1" LIBPROTOBUF="1.3.1" RASTER
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4211#comment:1>
