[postgis-tickets] [PostGIS] #4211: ST_Subdivide() on geometries with rings
PostGIS trac at osgeo.org
Mon Oct 22 08:28:20 PDT 2018
  Reporter:  morena   |      Owner:  komzpa
      Type:  defect   |     Status:  closed
  Priority:  high     |  Milestone:  PostGIS 2.5.1
 Component:  postgis  |    Version:  2.5.x
Resolution:  fixed    |   Keywords:  ST_Subdivide
Comment (by komzpa):
 morena, please try updating from latest branch and check that your data is
 all OK now. The case you reported should be OK starting from PostGIS
 2.5.1.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4211#comment:7>
