[postgis-tickets] [PostGIS] #3457: When a geometry is smaller than a raster but their extents are the same, one of the overloads of ST_Clip doesn't give expected output
PostGIS trac at osgeo.org
Tue Oct 23 05:29:11 PDT 2018
  Reporter:  GMudambi  |      Owner:  Bborie Park
      Type:  defect    |     Status:  new
  Priority:  critical  |  Milestone:  PostGIS 2.4.6
 Component:  raster    |    Version:  2.1.x
Resolution:            |   Keywords:
Comment (by saibot):
 Dear Jiří, users and developers,
 the st_clip function works incorrectly. I strongly recommend the following
 correction to all users. I hope that the bug will be fixed soon.
 CREATE OR REPLACE FUNCTION public.st_clip(
   rast      RASTER, nband INTEGER [], geom GEOMETRY,
   nodataval DOUBLE PRECISION [] DEFAULT NULL :: DOUBLE PRECISION [],
   crop      BOOLEAN DEFAULT TRUE)
   RETURNS RASTER AS
 $BODY$
 BEGIN
 -- wrong version
   -- short-cut if geometry's extent fully contains raster's extent
   -- IF (nodataval IS NULL OR array_length(nodataval, 1) < 1) AND geom ~
 ST_Envelope(rast)
 -- corrected version (bug-fix)
   -- no more short-cut!!!  if geometry's extent fully contains raster's
 extent
 st_contains(geom, ST_Envelope(rast))
   THEN RETURN rast;
   END IF;
   RETURN PUBLIC._ST_Clip($1, $2, $3, $4, $5);
 END;
 $BODY$
 LANGUAGE plpgsql
 IMMUTABLE
 COST 100;
 Thank you for all your work and best regards,
 Sai-bot
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3457#comment:8>
