[postgis-tickets] [PostGIS] #3457: When a geometry is smaller than a raster but their extents are the same, one of the overloads of ST_Clip doesn't give expected output
PostGIS trac at osgeo.org
Tue Oct 23 05:58:03 PDT 2018
  Reporter:  GMudambi  |      Owner:  komzpa
      Type:  defect    |     Status:  closed
  Priority:  critical  |  Milestone:  PostGIS 2.4.6
 Component:  raster    |    Version:  2.1.x
Resolution:  fixed     |   Keywords:
Changes (by komzpa):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"16940" 16940]:
 #!CommitTicketReference repository="" revision="16940"
 [raster] Fix envelope Contains shortcut in ST_Clip
 Patch by Sai-bot
 Closes #3457
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3457#comment:10>
