[postgis-tickets] r16942 - [raster] Fix envelope Contains shortcut in ST_Clip
Darafei komzpa at gmail.com
Tue Oct 23 06:05:58 PDT 2018
Author: komzpa
Date: 2018-10-23 06:05:58 -0700 (Tue, 23 Oct 2018)
New Revision: 16942
   branches/2.4/NEWS
   branches/2.4/raster/rt_pg/rtpostgis.sql.in
Patch by Sai-bot
Closes #3457
Modified: branches/2.4/NEWS
--- branches/2.4/NEWS	2018-10-23 13:00:11 UTC (rev 16941)
+++ branches/2.4/NEWS	2018-10-23 13:05:58 UTC (rev 16942)
@@ -10,6 +10,7 @@
   - #4191, Fix undefined behaviour in ptarray_clone_deep (Raúl Marín)
   - #4020, Fix leftovers in topology upgrade from 2.1 (Sandro Santilli)
   - #4206, Fix support for PostgreSQL 12 dev branch (Laurenz Albe)
+  - #3457, Fix raster envelope shortcut in ST_Clip (Sai-bot)
 PostGIS 2.4.5
Modified: branches/2.4/raster/rt_pg/rtpostgis.sql.in
--- branches/2.4/raster/rt_pg/rtpostgis.sql.in	2018-10-23 13:00:11 UTC (rev 16941)
+++ branches/2.4/raster/rt_pg/rtpostgis.sql.in	2018-10-23 13:05:58 UTC (rev 16942)
@@ -6701,7 +6701,7 @@
  	AS $$
 	BEGIN
 		-- short-cut if geometry's extent fully contains raster's extent
-		IF (nodataval IS NULL OR array_length(nodataval, 1) < 1) AND geom ~ ST_Envelope(rast) THEN
+		IF (nodataval IS NULL OR array_length(nodataval, 1) < 1) AND ST_Contains(geom, ST_Envelope(rast)) THEN
 			RETURN rast;
 		END IF;
