[postgis-tickets] [PostGIS] #4215: Drop usage of GDALPolygonize in DT_DumpAsPolygons
trac at osgeo.org
Wed Oct 24 07:02:35 PDT 2018
Reporter: komzpa | Owner: komzpa
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.4.6
Component: raster | Version: 2.4.x
Resolution: fixed | Keywords:
Changes (by komzpa):
* status: assigned => closed
* resolution: => fixed
Comment:
In [changeset:"16946" 16946]:
#!CommitTicketReference repository="" revision="16946"
[raster] Use GDALFPolygonize unconditionally
GDAL 1.10 is already required and 1.9 contains it, so no check needed.
Closes #4215
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4215#comment:3>
