[postgis-tickets] r16950 - Fix typo in upgrade message
Daniel Baston dbaston at gmail.com
Thu Oct 25 04:52:10 PDT 2018
Author: dbaston
Date: 2018-10-25 04:52:10 -0700 (Thu, 25 Oct 2018)
New Revision: 16950
   trunk/extensions/postgis/unpackage_raster_if_needed.sql
Modified: trunk/extensions/postgis/unpackage_raster_if_needed.sql
--- trunk/extensions/postgis/unpackage_raster_if_needed.sql	2018-10-24 21:56:42 UTC (rev 16949)
+++ trunk/extensions/postgis/unpackage_raster_if_needed.sql	2018-10-25 11:52:10 UTC (rev 16950)
@@ -14,7 +14,7 @@
 		-- UNPACKAGE_CODE --
 		$unpackage$;
-		RAISE WARNING 'PostGIS Raster functionality have been unpackaged'
+		RAISE WARNING 'PostGIS Raster functionality has been unpackaged'
 		USING HINT = 'type `SELECT postgis_extensions_upgrade(); to finish the upgrade.'
 						' After upgrading, if you want to drop raster, run: DROP EXTENSION postgis_raster;';
 	END IF;
