[postgis-tickets] r16955 - ST_Subdivide: don't crash if on some iteration you need to subdivide Empty
Darafei komzpa at gmail.com
Sun Oct 28 08:18:07 PDT 2018
Author: komzpa
Date: 2018-10-28 20:18:07 -0700 (Sun, 28 Oct 2018)
New Revision: 16955
   trunk/liblwgeom/lwgeom.c
   trunk/regress/core/subdivide.sql
   trunk/regress/core/subdivide_expected
Closes #4217
Closes https://github.com/postgis/postgis/pull/321
Modified: trunk/liblwgeom/lwgeom.c
--- trunk/liblwgeom/lwgeom.c	2018-10-27 10:23:03 UTC (rev 16954)
+++ trunk/liblwgeom/lwgeom.c	2018-10-29 03:18:07 UTC (rev 16955)
@@ -2342,43 +2342,30 @@
 	++depth;
-	LWCOLLECTION *col1 =
-	    lwcollection_construct_empty(COLLECTIONTYPE, geom->srid, lwgeom_has_z(geom), lwgeom_has_m(geom));
-	LWCOLLECTION *col2 =
-	//#pragma omp parallel sections
-		//#pragma omp section
+		LWGEOM *subbox = (LWGEOM *)lwpoly_construct_envelope(
+		    geom->srid, subbox1.xmin, subbox1.ymin, subbox1.xmax, subbox1.ymax);
+		LWGEOM *clipped = lwgeom_intersection(geom, subbox);
+		lwgeom_simplify_in_place(clipped, 0.0, LW_TRUE);
+		lwgeom_free(subbox);
+		if (clipped && !lwgeom_is_empty(clipped))
-			LWGEOM *subbox = (LWGEOM *)lwpoly_construct_envelope(
-			    geom->srid, subbox1.xmin, subbox1.ymin, subbox1.xmax, subbox1.ymax);
-			LWGEOM *clipped = lwgeom_intersection(geom, subbox);
-			lwgeom_simplify_in_place(clipped, 0.0, LW_TRUE);
-			lwgeom_free(subbox);
-			if (clipped)
-				lwgeom_subdivide_recursive(clipped, dimension, maxvertices, depth, col1);
-				lwgeom_free(clipped);
+			lwgeom_subdivide_recursive(clipped, dimension, maxvertices, depth, col);
+			lwgeom_free(clipped);
+		    geom->srid, subbox2.xmin, subbox2.ymin, subbox2.xmax, subbox2.ymax);
-			    geom->srid, subbox2.xmin, subbox2.ymin, subbox2.xmax, subbox2.ymax);
-			if (clipped)
-				lwgeom_subdivide_recursive(clipped, dimension, maxvertices, depth, col2);
-	col = lwcollection_concat_in_place(col, col1);
-	lwcollection_release(col1);
-	col = lwcollection_concat_in_place(col, col2);
-	lwcollection_release(col2);
 LWCOLLECTION *
Modified: trunk/regress/core/subdivide.sql
--- trunk/regress/core/subdivide.sql	2018-10-27 10:23:03 UTC (rev 16954)
+++ trunk/regress/core/subdivide.sql	2018-10-29 03:18:07 UTC (rev 16955)
@@ -60,3 +60,6 @@
 drop table big_polygon_sliced;
 select '#4211', (select sum(ST_Area(geom))::numeric(12,11) from ST_Subdivide('MULTIPOLYGON(((-88.2059 41.7325,-88.2060 41.7244,-88.1959 41.7241,-88.1959 41.7326,-88.2059 41.7325),(-88.1997 41.7289,-88.1996 41.7285,-88.1990 41.7285,-88.1990 41.7289,-88.1997 41.7289)))') geom );
+select '#4217', (select sum(ST_Area(geom))::numeric(12,11) from ST_Subdivide('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
 9C593E45057C062537A4475844640380D6241EF5057C062537A4475844640', 10) geom);
Modified: trunk/regress/core/subdivide_expected
--- trunk/regress/core/subdivide_expected	2018-10-27 10:23:03 UTC (rev 16954)
+++ trunk/regress/core/subdivide_expected	2018-10-29 03:18:07 UTC (rev 16955)
@@ -6,3 +6,4 @@
 #3744|1600000000000000
 4|29321996468.6|29321996468.6|1857|256
 #4211|0.00008316000
+#4217|0.00002463668
