[postgis-tickets] [PostGIS] #4210: PostGIS 3.0 is completely broken
PostGIS trac at osgeo.org
Mon Oct 29 11:54:47 PDT 2018
  Reporter:  robe     |      Owner:  strk
      Type:  defect   |     Status:  reopened
  Priority:  blocker  |  Milestone:  PostGIS 3.0.0
 Component:  postgis  |    Version:  trunk
Resolution:           |   Keywords:
Changes (by robe):
 * status:  closed => reopened
 * resolution:  fixed =>
Comment:
 They are still all broken
 Now with this error:
  geography .. failed (diff expected obtained:
 /projects/postgis/tmp/3.0.0dev_pg10_geos3.7.0_gdal2.2.4w64/test_3_diff)
 --- geography_expected  2018-09-11 02:20:56.083471300 -0400
 +++ /projects/postgis/tmp/3.0.0dev_pg10_geos3.7.0_gdal2.2.4w64/test_3_out
 2018-10-29 11:03:40.592624400 -0400
 @@ -1,3 +1,4 @@
 +ERROR:  duplicate key value violates unique constraint
 "spatial_ref_sys_pkey"
  geog_distance_cached_1a|t
  geog_distance_cached_1b|t
  geog_distance_cached_1c|t
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4210#comment:5>
