[postgis-tickets] r16964 - Update HTML document styling to new "standard"
Paul Ramsey pramsey at cleverelephant.ca
Tue Oct 30 12:47:52 PDT 2018
Author: pramsey
Date: 2018-10-30 12:47:52 -0700 (Tue, 30 Oct 2018)
New Revision: 16964
Added:
   branches/2.5/doc/html/ga.js
   branches/2.5/doc/Makefile.in
   branches/2.5/doc/html/style.css
Modified: branches/2.5/doc/Makefile.in
--- branches/2.5/doc/Makefile.in	2018-10-30 18:40:53 UTC (rev 16963)
+++ branches/2.5/doc/Makefile.in	2018-10-30 19:47:52 UTC (rev 16964)
@@ -58,13 +58,19 @@
 	--param funcsynopsis.style kr \
 	--param admon.graphics 1 \
 	--param admon.textlabel 0 \
+	--param make.clean.html 1 \
 	--param simplesect.in.toc 0 \
 	--param use.id.as.filename 1 \
 	--param chunk.quietly 1 \
+	--param header.rule 0 \
+	--param footer.rule 0 \
+	--param table.borders.with.css 1 \
+	--stringparam chunker.output.encoding UTF-8 \
+	--stringparam chunker.output.indent no \
+	--stringparam saxon.character.representation decimal \
+	--stringparam html.stylesheet style.css \
 	$(XSLTPROCFLAGS)
-XSLTPROC_HTMLOPTS= \
-	--stringparam html.stylesheet style.css \
 HTML_DOCBOOK_XSL=$(XSLBASE)/html/docbook.xsl
 CHUNK_HTML_DOCBOOK_XSL=$(XSLBASE)/html/chunk.xsl
@@ -137,7 +143,7 @@
 	reporting.xml \
 	using_postgis_app.xml \
 	using_postgis_dataman.xml \
-	using_raster_dataman.xml
+	using_raster_dataman.xml
 XML_GENERATED_SOURCES = \
 	postgis_aggs_mm.xml \
@@ -208,31 +214,31 @@
 postgis_comments.sql: ./xsl/postgis_comments.sql.xsl $(XML_INPUTS)
 	$(XSLTPROC) --novalid ./xsl/postgis_comments.sql.xsl postgis-out.xml > $@
 postgis_cheatsheet.html: ./xsl/postgis_cheatsheet.html.xsl $(XML_INPUTS)
 	$(XSLTPROC) --novalid ./xsl/postgis_cheatsheet.html.xsl postgis-out.xml > $@
 raster_comments.sql: ./xsl/raster_comments.sql.xsl $(XML_INPUTS)
 	$(XSLTPROC) --novalid ./xsl/raster_comments.sql.xsl postgis-out.xml > $@
 raster_cheatsheet.html: ./xsl/raster_cheatsheet.html.xsl $(XML_INPUTS)
 	$(XSLTPROC) --novalid ./xsl/raster_cheatsheet.html.xsl postgis-out.xml > $@
 topology_comments.sql: ./xsl/topology_comments.sql.xsl $(XML_INPUTS)
 	$(XSLTPROC) --novalid ./xsl/topology_comments.sql.xsl postgis-out.xml > $@
 topology_cheatsheet.html: ./xsl/topology_cheatsheet.html.xsl $(XML_INPUTS)
 	$(XSLTPROC) --novalid ./xsl/topology_cheatsheet.html.xsl postgis-out.xml > $@
 sfcgal_comments.sql: ./xsl/sfcgal_comments.sql.xsl $(XML_INPUTS)
 	$(XSLTPROC) --novalid ./xsl/sfcgal_comments.sql.xsl postgis-out.xml > $@
 sfcgal_cheatsheet.html: ./xsl/sfcgal_cheatsheet.html.xsl $(XML_INPUTS)
 	$(XSLTPROC) --novalid ./xsl/sfcgal_cheatsheet.html.xsl postgis-out.xml > $@
 tiger_geocoder_comments.sql: ./xsl/tiger_geocoder_comments.sql.xsl $(XML_INPUTS)
 	$(XSLTPROC) --novalid ./xsl/tiger_geocoder_comments.sql.xsl postgis-out.xml > $@
 tiger_geocoder_cheatsheet.html: ./xsl/tiger_geocoder_cheatsheet.html.xsl $(XML_INPUTS)
 	$(XSLTPROC) --novalid ./xsl/tiger_geocoder_cheatsheet.html.xsl postgis-out.xml > $@
@@ -240,12 +246,19 @@
 	$(PERL) -lpe "s'@@LAST_RELEASE_VERSION@@'${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGIS_MICRO_VERSION}'g;s'@@POSTGIS_DOWNLOAD_URL@@'${POSTGIS_DOWNLOAD_URL}'g;" $< > $@
 chunked-html: postgis-out.xml Makefile images $(XML_INPUTS)
-	$(XSLTPROC) $(XSLTPROC_COMMONOPTS) $(XSLTPROC_HTMLOPTS) \
+	$(XSLTPROC) $(XSLTPROC_COMMONOPTS) \
 		--output html/ \
-		--stringparam saxon.character.representation decimal \
 		$(CHUNK_HTML_DOCBOOK_XSL) \
+chunked-html-web: postgis-out.xml Makefile images $(XML_INPUTS)
+		--output html/ \
+		--stringparam html.script ga.js \
+		$(CHUNK_HTML_DOCBOOK_XSL) \
 html: html/postgis$(DOCSUFFIX).html
 html-localized:
@@ -255,7 +268,7 @@
   done
 html/postgis$(DOCSUFFIX).html: postgis-out.xml Makefile images $(XML_INPUTS)
 		--output html/postgis$(DOCSUFFIX).html \
 		$(HTML_DOCBOOK_XSL) \
@@ -279,7 +292,7 @@
 		   -s "${PWD}/texstyle.sty" \
 		   -o postgis-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGIS_MICRO_VERSION}$(DOCSUFFIX).pdf $<; \
 	fi
 postgis-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGIS_MICRO_VERSION}$(DOCSUFFIX).epub: postgis-out.xml images $(XML_INPUTS)
 	if test x"$(DBTOEPUB)" = x; then \
 	   echo "Error: dbtoepub not found, can't build epub"; \
@@ -307,13 +320,13 @@
 doxygen: doxygen.cfg
 	doxygen $<
-images:
+images:
 	$(MAKE) -C html/image_src images
 images-clean:
 	$(MAKE) -C html/image_src images-clean
-clean:
+clean:
 	rm -f html/*.html
 	rm -f postgis-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGIS_MICRO_VERSION}.pdf
 	rm -f *.epub
@@ -338,7 +351,7 @@
 cheatsheets: postgis_cheatsheet.html raster_cheatsheet.html topology_cheatsheet.html sfcgal_cheatsheet.html tiger_geocoder_cheatsheet.html
 ifneq ($(CAN_BUILD_COMMENTS),yes)
-comments-install:
+comments-install:
 	if test -e postgis_comments.sql  -a \
 	        -e raster_comments.sql   -a \
 	        -e topology_comments.sql -a \
@@ -370,7 +383,7 @@
 	$(INSTALL_DATA) html/images/* $(DESTDIR)$(PGSQL_DOCDIR)/postgis/images/
 	$(INSTALL_DATA) ../README.postgis $(DESTDIR)$(PGSQL_DOCDIR)/postgis/README.postgis
-docs-uninstall:
+docs-uninstall:
 	rm -f $(DESTDIR)$(PGSQL_DOCDIR)/postgis/postgis.html
 	rm -f $(DESTDIR)$(PGSQL_DOCDIR)/postgis/style.css
 	rm -rf $(DESTDIR)$(PGSQL_DOCDIR)/postgis/images
@@ -436,11 +449,11 @@
 	@echo
 requirements_not_met_imagemagick:
-	@echo
+	@echo
 	@echo "configure was unable to find the ImageMagick's 'convert' utility program."
 	@echo "To build the documentation, install ImageMagick and then re-run configure. Alternatively "
 	@echo "refer to online manual:"
 	@echo
 	@echo "  http://postgis.net/documentation"
-	@echo
+	@echo
Index: branches/2.5/doc/html
--- branches/2.5/doc/html	2018-10-30 18:40:53 UTC (rev 16963)
+++ branches/2.5/doc/html	2018-10-30 19:47:52 UTC (rev 16964)
Property changes on: branches/2.5/doc/html
___________________________________________________________________
Modified: svn:ignore
## -1 +1,2 ##
-*.html
\ No newline at end of property
+*.html
+docbook.css
Added: branches/2.5/doc/html/ga.js
--- branches/2.5/doc/html/ga.js	                        (rev 0)
+++ branches/2.5/doc/html/ga.js	2018-10-30 19:47:52 UTC (rev 16964)
@@ -0,0 +1,7 @@
+(function(i,s,o,g,r,a,m){i['GoogleAnalyticsObject']=r;i[r]=i[r]||function(){
+(i[r].q=i[r].q||[]).push(arguments)},i[r].l=1*new Date();a=s.createElement(o),
+m=s.getElementsByTagName(o)[0];a.async=1;a.src=g;m.parentNode.insertBefore(a,m)
+})(window,document,'script','https://www.google-analytics.com/analytics.js','ga');
+ga('create', 'UA-37775762-1', 'auto');
+ga('send', 'pageview');
Modified: branches/2.5/doc/html/style.css
--- branches/2.5/doc/html/style.css	2018-10-30 18:40:53 UTC (rev 16963)
+++ branches/2.5/doc/html/style.css	2018-10-30 19:47:52 UTC (rev 16964)
@@ -1,51 +1,263 @@
-/* PostGIS Alternative Docbook CSS | Dane Springmeyer
+* PostGIS Alternative Docbook CSS
+* Dane Springmeyer
+* Paul Ramsey
-/* 1. Body
+/* 1. Body ----------------------------------------------------- */
+body {
+    font: 100% 'Lucida Grande', Verdana, Geneva, Arial, Helvetica, sans-serif;
+    background: #ffffff;
+    color: #2e2e2e;
+    margin: 0;
+    padding: 0em 6em 0em 6em;
+div.navheader {
+    margin: 0em -6em 0em -6em;
+    padding: 2em 6em 2em 6em;
+    background: #579;
-body { font: 90% 'Lucida Grande', Verdana, Geneva, Arial, Helvetica, sans-serif; background: #ffffff; color: #2e2e2e; margin: 2em; padding: 2em; }
+div.navfooter {
+    background: #579;
+    color: white;
+div.navfooter table {
+    color: white;
-/* 2. Standard Tags
+div.navheader table tbody tr:first-child th {
+    color: white;
+    font-size: 140%;
+    font-style: normal;
-a {text-decoration: none; color: #418acd; }
-a:hover, li a:hover, h2 a:hover, h3 a:hover, h4 a:hover, h5 a:hover {color: #e9cb2b; }
-p,form,td,th,dt,li{font-size:10pt}
-h1, h2 {color: #282e5b;}
-h3,h4,th,dt,b {color: #213780;}
-h1 { font-size: 24px; line-height: 24px; margin-bottom: 24px;}
-h2 { font-size: 22px; line-height: 22px; margin-bottom: 21px;}
-h3 { font-size: 16px; line-height: 18px; margin-bottom: 16px;}
-h4 { font-size: 14px; line-height: 16px; margin-bottom: 14px;}
-h5 { font-size: 13px; line-height: 10px; margin-bottom: 13px;}
-table, td {border-collapse: collapse;}
-/*table, td {border: 1;padding: 0}
+div.navheader table tbody tr:nth-child(2) {
+    display: none;
-/* 3. Block Formatted
-pre, .literallayout { border-right-width: 0px; border-left-width: 0px; border-bottom-width: 2px; border-top-width: 2px; font-family: "DejaVu Sans", "Lucida Grande", "Verdana", Courier, mono; line-height: 16px; border-color: #f7931e; border-style: solid; font-size: 11px; margin-bottom: 10px; margin-top: 10px; overflow: auto; padding: 10px; background: #f8f8f9; -moz-border-radius: 2px; -webkit-border-radius: 2px;}
-.note { border-left-width: 0px; border-bottom-width: 2px; border-right-width: 0px; border-top-width: 2px; width: 80%; border-color: #a2d545; border-style: solid; font-size: 11px; margin-bottom: 10px; margin-top: 10px; overflow: auto; padding: 10px; background: #e4f7dd; -moz-border-radius: 2px; -webkit-border-radius: 2px;}
-/* code { border-right-style: solid; border-right-color: #79791a; border-left-color: #79791b; border-left-style: solid; border-left-width: 0px; border-bottom-width: 0px; border-right-width: 0px; border-top-width: 0px; padding-left: 3px; padding-bottom: 1px; padding-right: 3px; padding-top: 1px; font-family: "Courier New", Courier, Monaco, monospace; color: #fefff7; background: #9b9e96; -moz-border-radius: 2px; -webkit-border-radius: 2px;} */
-.programlisting {font-family: "Courier New", Courier, Monaco, monospace;}
-.warning { border-left-width: 0px; border-bottom-width: 2px; border-right-width: 0px; border-top-width: 2px; width: 80%; border-color: #a2d545; border-style: solid; font-size: 11px; margin-bottom: 10px; margin-top: 10px; overflow: auto; padding: 10px; background: #FFE699; -moz-border-radius: 2px; -webkit-border-radius: 2px;}
+div.navfooter a {
+    text-decoration: none;
+    color: #bcF;
+div.navfooter a:hover {
+    color: #e9cb2b;
-/* 4. Docbook Specifics
-.question {font-weight: bold; color: #213780;}
-.term { font-weight: bold; color: #38488d;}
-.term:hover { font-weight: bold; color: #88000f;}
-.chapter { margin-top: 60px; }
-.sect1 { margin-top: 50px; }
-.sect2 { margin-top: 40px; }
-.sect3 { margin-top: 30px; }
-.caption p {font-style: italic; font-size: 90%;}
-.remark { background: #ffff00; }
-.equation {font-style: italic; font-size: 90%;}
-.command, .code {font-weight: normal; font-family: "Courier New", Courier, Monaco, monospace; color: #000000;}
-.styledtable table thead th { border-right-width: 0px; border-left-width: 0px; border-bottom-width: 1px; border-top-width: 0px; border-color: #f7931e; border-style: solid;  }
-.styledtable > table { border-right-width: 0px; border-left-width: 0px; border-bottom-width: 2px; border-top-width: 2px; border-color: #f7931e; border-style: solid;  }
-.styledtable table td,th { color: #000000; font-style: italic; padding-right:10px; padding-left:10px; border-right-width: 0px; border-left-width: 0px; border-bottom-width: 2px; border-top-width: 2px; border-width: 0px;}
-.pdparam {color: #990000}
+div.refnamediv {
+    display: none;
+div.funcsynopsis code {
+    font: unset;
+/* 2. Standard Tags ----------------------------------------------------- */
+a {
+    color: #55d;
+a:hover, li a:hover, h2 a:hover, h3 a:hover, h4 a:hover, h5 a:hover {
+    color: #e9cb2b;
+p, form, td, th, dt, li {
+/*   font-size:10pt */
+h1, h2 {
+    color: #579;
+h3, h4, th, dt, b, div.abstract-title, div.toc-title {
+    color: #579;
+h1 {
+     font-size: 175%;
+     margin-top: 1.2em;
+     margin-bottom: 0.5em;
+h2 {
+    font-size: 150%;
+h3, div.abstract-title, div.toc-title {
+    font-size: 130%;
+    margin-top: 1.1em;
+    margin-bottom: 0.4em;
+h4 {
+    font-size: 120%;
+    margin-top: 1em;
+    margin-bottom: 0.3em;
+h5 {
+    font-size: 110%;
+    margin-top: 1em;
+table, td {
+    border-collapse: collapse;
+/* 3. Block Formatted ----------------------------------------------------- */
+pre, .literallayout {
+    border-width: 0;
+    font-family: Consolas, Monaco, monospace;
+    border-style: solid;
+    margin-bottom: 1em;
+    margin-top: 1em;
+    overflow: auto;
+    padding: 1em;
+    background: #eee;
+    border-radius: 1em;
+div.note {
+    font-size: 90%;
+    border-color: #dd5;
+    border-width: 1.5px;
+    margin-top: 1em;
+    overflow: auto;
+    padding: 0.8em;
+    background: #ffe;
+div.note table p {
+    font-size: 90%;
+    margin: 0 0 0 0;
+    padding: 0 0 0 0;
+div.note table tr td img {
+    margin: 0 0.5em 0 0;
+    padding: 0 0 0 0;
+div.warning {
+    font-size: 90%;
+    border-color: #cc5555;
+    margin-top: 1em;
+    overflow: auto;
+    padding: 0.8em;
+    background: #FFf1f1;
+div.warning table p {
+    font-size: 90%;
+    margin: 0 0 0 0;
+    padding: 0 0 0 0;
+div.warning table tr td img {
+    padding: 0 0 0 0;
+div.important {
+    font-size: 90%;
+    border-color: #55d;
+    margin-top: 1em;
+    overflow: auto;
+    padding: 0.8em;
+    background: #eef;
+div.important table p {
+    font-size: 90%;
+    margin: 0 0 0 0;
+    padding: 0 0 0 0;
+div.important table tr td img {
+    padding: 0 0 0 0;
+span.inlinemediaobject img {
+    vertical-align: middle;
+.programlisting {
+/* 4. Docbook Specifics ----------------------------------------------------- */
+span.emphasis {
+    font-style: italic;
+tr.question {
+    font-weight: bold;
+    color: #248;
+tr.question td {
+    padding-bottom: 0.5em;
+    padding-top: 0.4em;
+.term {
+    color: #459;
+.term:hover {
+    color: #801;
+.chapter {
+    margin-top: 60px;
+.sect1 {
+    margin-top: 50px;
+.sect2 {
+    margin-top: 40px;
+.sect3 {
+    margin-top: 30px;
+.caption p {
+.remark {
+    background: #ff0;
+.equation {
+.command, .code, .varname, .filename {
+    font-size: 105%;
+    font-weight: normal;
+    color: black;
+    background-color: #eee;
+.styledtable table td,th {
+    padding: 0.5em;
+table.informaltable {
+    border-color: #aaa;
+table.informaltable td, th {
+    padding: 0.2em 0.4em 0.2em 0.4em;
+.pdparam {
+    color: #900
+.simplelist td {
+    padding-right: 2em;
