[postgis-tickets] [PostGIS] #4210: PostGIS 3.0 is completely broken
PostGIS trac at osgeo.org
Wed Oct 31 05:07:28 PDT 2018
  Reporter:  robe     |      Owner:  strk
      Type:  defect   |     Status:  closed
  Priority:  blocker  |  Milestone:  PostGIS 3.0.0
 Component:  postgis  |    Version:  trunk
Resolution:  fixed    |   Keywords:
Comment (by strk):
 Thanks for fixing this Regina !
 Just a comment: a left-over entry in spatial-ref-sys sounds like
 a bug in a previously run test. I think it would make more sense
 to fix the previous test to cleanup after itself rather than
 (or in addition to) making tests tolerate a possibly dirty
 starting point.
 Beside, we might want to _avoid_ using system SRIDs for tests
 (what if you run run_test.pl --nocreate and set PGIS_REG to
 an existing database?)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4210#comment:9>
