[postgis-tickets] [PostGIS] #4166: legacy regress test is broken
PostGIS trac at osgeo.org
Sun Sep 2 18:08:24 PDT 2018
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  reopened
  Priority:  blocker  |  Milestone:  PostGIS 3.0.0
 Component:  postgis  |    Version:  trunk
Resolution:           |   Keywords:
Changes (by robe):
 * status:  closed => reopened
 * resolution:  fixed =>
Comment:
 Still failing on legacy regress for winnie
 legacy .. failed (diff expected obtained:
 /projects/postgis/tmp/3.0.0dev_pg10_geos3.7.0dev_gdal2.2.4w64/test_50_diff)
 --- legacy_expected     2017-10-26 19:18:11.560448900 -0400
 /projects/postgis/tmp/3.0.0dev_pg10_geos3.7.0dev_gdal2.2.4w64/test_50_out
 2018-09-02 20:34:23.415531500 -0400
 @@ -1,21 +1,9691 @@
 +\cd: could not change directory to
 "E:/jenkins/postgresql/rel/pg10w64gcc48/share/contrib/postgis-3.": No such
 file or directory
 +psql:legacy.sql:11: \cd: could not change directory to
 file or directory
 Though not failing on debbie, anymore but she's not happy with raster.
 Will post a separate ticket for that.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4166#comment:5>
