[postgis-tickets] [PostGIS] #4167: raster regress failing on debbie
PostGIS trac at osgeo.org
Sun Sep 2 18:12:58 PDT 2018
 Reporter:  robe       |      Owner:  robe
     Type:  defect     |     Status:  new
 Priority:  blocker    |  Milestone:  PostGIS 3.0.0
Component:  buildbots  |    Version:  trunk
 Keywords:             |
 This could be an upstream issue:
 PostgreSQL 10.5 on x86_64-pc-linux-gnu, compiled by gcc (Debian 8.2.0-4)
 8.2.0, 64-bit
   Postgis 3.0.0dev - r16712 - 2018-09-02 19:03:31
   scripts 3.0.0dev r16712
   raster scripts 3.0.0dev r16712
   GEOS: 3.7.0rc1-CAPI-1.11.0 49f66217
   PROJ: Rel. 5.1.0, June 1st, 2018
   GDAL: GDAL 2.3.1, released 2018/06/22
 Running tests
  check_gdal .. ok
  load_outdb ... ok
  check_raster_columns .. ok
  check_raster_overviews .. ok
  rt_io .. ok
  rt_bytea .. ok
  rt_wkb .. ok
  box3d .. ok
  rt_addband .. ok
  rt_band .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/tmp/3_0_pg10w64/test_10_diff)
 --- rt_band_expected    2018-08-19 22:53:09.856397544 +0000
 +++ /var/lib/jenkins/workspace/postgis/tmp/3_0_pg10w64/test_10_out
 2018-09-02 19:10:29.734026148 +0000
 @@ -12,18 +12,7 @@
  9876.54321
  987.654321
  1234.5678
 -1234.5678
 -1234.5678
 -1234.5678
 -4
 -3
 -2
 -1
 -1
 -1
 -NOTICE:  Invalid band index (must use 1-based). Returning original raster
 -3
 -3
 -1234.5678
 -987.654321
 +server closed the connection unexpectedly
 +       This probably means the server terminated abnormally
 +       before or while processing the request.
 +connection to server was lost
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4167>
