[postgis-tickets] [PostGIS] #4169: Set `html-chinked` as a default for docs
PostGIS trac at osgeo.org
Mon Sep 3 22:21:24 PDT 2018
 Reporter:  pcav           |      Owner:  robe
     Type:  defect         |     Status:  new
 Priority:  low            |  Milestone:  PostGIS 2.5.0
Component:  documentation  |    Version:  2.4.x
 Keywords:                 |
 Currently the default for building the doc is a single paage called
 postgs.html. This causes some minor problems:
 * not being called `index.html` it is not rendered by default in apache
 * being pretty large it requires a long time to load aand render.
 Packages (e.g. Debian) take the default.
 I suggest therefore to use the target `html-chunked` as a default, and
 rename the output.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4169>
