[postgis-tickets] [PostGIS] #2909: bad dependency expression results in rule firing on subsequent make, and make install
PostGIS trac at osgeo.org
Tue Sep 4 10:18:03 PDT 2018
make install
  Reporter:  gdt                    |      Owner:  strk
      Type:  defect                 |     Status:  closed
  Priority:  low                    |  Milestone:  PostGIS 2.2.8
 Component:  build/upgrade/install  |    Version:  2.1.x
Resolution:  fixed                  |   Keywords:
Changes (by gdt):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 This is fixed in 2.5.0rc1, so I'm just closing it to clean up, without
 figuring out where it was fixed along the way.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/2909#comment:9>
