[postgis-tickets] [PostGIS] #4170: ERROR: Upgrade of postgis from version 2.1.9 r15770 to version 3.0 requires a dump/reload. See PostGIS manual for instructions
PostGIS trac at osgeo.org
Wed Sep 5 08:39:57 PDT 2018
  Reporter:  strk     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 2.4.5
 Component:  postgis  |    Version:  2.4.x
Resolution:           |   Keywords:
Comment (by strk):
 The message comes from a check produced by utils/postgis_proc_upgrade.pl,
 specifically added to avoid incompatible upgrades:
   IF old_maj != new_maj THEN
     RAISE EXCEPTION ''Upgrade of MODULE from version % to version %
 requires a dump/reload. See PostGIS manual for instructions'',
 old_scripts, new_scripts;
   ELSE
     RETURN ''Scripts versions checked for upgrade: ok'';
   END IF;
 Theoretically, that check should make loading postgis_ugrade.sql safe
 (doing nothing) when the target version is a major version higher than the
 source version of PostGIS, assuming a change in Major version will always
 only occur when the storage format changes, and thus assuming that
 changing input/output functions would in this case result in an unusable
 database.
 As we changed Major version w/out such an occurrence we should ask
 ourselves whether we want to change semantic of Major version OR we want
 to differently determine if dump/reload is required in order NOT to brick
 someone's database...
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4170#comment:1>
