[postgis-tickets] [PostGIS] #4170: ERROR: Upgrade of postgis from version 2.1.9 r15770 to version 3.0 requires a dump/reload. See PostGIS manual for instructions
PostGIS trac at osgeo.org
Wed Sep 5 09:24:35 PDT 2018
  Reporter:  strk                   |      Owner:  strk
      Type:  defect                 |     Status:  closed
  Priority:  medium                 |  Milestone:  PostGIS 2.4.5
 Component:  build/upgrade/install  |    Version:  trunk
Resolution:  fixed                  |   Keywords:
Changes (by strk):
 * status:  assigned => closed
 * resolution:   => fixed
Comment:
 In [changeset:"16713" 16713]:
 #!CommitTicketReference repository="" revision="16713"
 Consider 3.x upgrade-compatible with 2.x
 Closes #4170
 As I was at it, I also replaced the use of a temporary function
 with a DO block.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4170#comment:3>
