[postgis-tickets] [PostGIS] #4137: PostGIS 2.5.0beta1 fails tests on MIPS
PostGIS trac at osgeo.org
Mon Sep 10 15:02:17 PDT 2018
  Reporter:  komzpa   |      Owner:  pramsey
      Type:  defect   |     Status:  reopened
  Priority:  medium   |  Milestone:  PostGIS 2.5.0
 Component:  postgis  |    Version:  trunk
Resolution:           |   Keywords:
Changes (by komzpa):
 * status:  closed => reopened
 * resolution:  fixed =>
Comment:
 Please click the green "Installed" link. There you can see a test failure:
  tickets .. failed (diff expected obtained: /tmp/pgis_reg/test_95_diff)
 --- tickets_expected    2018-08-19 21:46:50.000000000 +0000
 +++ /tmp/pgis_reg/test_95_out   2018-08-20 08:19:44.274423637 +0000
 @@ -178,7 +178,7 @@
  #1453.2|f
  #1454|t
  #1414|CURVEPOLYGON Z EMPTY
 -#1478|010100002001000000000000000000f87f000000000000f87f
 +#1478|010100002001000000fffffffffffff77ffffffffffffff77f
  #745|GEOMETRYCOLLECTION(POLYGON((-72 42 1,-70 43 1,-71 41 1,-72 42 1)))
  #1450|POINT|POLYGON
  #1482|4326
 @@ -269,69 +269,7 @@
  #2788|f|Self-intersection|POINT(1 1)
  #2870|Point[GS]
  #2956|t
 -#2985|LINESTRING(20.9511664253809 52.3984560730436)
 -#2996|247.44|247.44
 -#3119a|121
 -#3119b|291
 -#3119c|615
 -#3119d|291
 -#3172|LINESTRING M (0 0 1,0 0 2)
 -#3300|POLYGON((-71.7821 42.2622,-71.7821 42.9067,-71.029 42.9067,-71.029
 42.2622,-71.7821 42.2622))
 -#3355|t
 -#3356|LineString[] with 2 points|LineString[GS] with 2
 points|LineString[GS] with 2 points
 -#3356|LineString[B] with 3 points|LineString[BGS] with 3
 points|LineString[BGS] with 3 points
 -#3367|POLYGON EMPTY
 -#3368|\x660001011fb98788d35ed6fbcdc831c580012b959f01469d8d0e9305ff8618ed08b1b607e302a614fe70bc4682b303b4379ab503a228eeb603e2138eb802900cc0b802ba04dab802b801a8840cb0229cca06f401c216f403a016ea05d0c301a8b301cc189226ac15ee27f811a029b40eac2ae00a902b8407c82b9e03d0e305801dfad3239504ce7e8d01e2f701f6019b04d1e2279bf901ff01
 -#3375|GEOMETRYCOLLECTION(POINT(0 -7))
 -#3399|1|1
 -#3399|10|10
 -#3399|100|100
 -#3399|1000|1000
 -ERROR:  invalid KML representation
 -#3437a|5
 -#3437b|5
 -#3437c|5
 -#3437d|5
 -#3437e|5
 -#3470|t
 -#3470b|50
 -#3569|BOX(1 2,3 4)
 -#3578a|0
 -#3578b|0
 -#3579|f|t
 -#3620a|POINT(3 7)
 -#3620b|POINT(2 8)
 -#3627a|o}~~|AdshNoSsBgd at eGoBlm@wKhj@~@?
 -#3627b|t
 -#3704|t
 -#3709|t
 -#3774|t
 -#1014a|POINT(0 0)
 -#1014a|POINT(0 0)
 -#1014b|POINT(0 1)
 -#1014c|1|POINT(0 1)
 -#1014c|2|POINT(1 2)
 -#1014c|3|POINT(2 3)
 -#1014d|SRID=1;POINT(0 1)
 -#1014d|SRID=2;POINT(0 1)
 -#3930|62065
 -NOTICE:  Too few points in geometry component at or near point 0 0
 -#4011|ST_LineString|LINESTRING(0 0,1 1)|f|t
 -#4011|ST_LineString|MULTILINESTRING((0 0,1 1),(1 1,2 2))|f|t
 -#4011|ST_LineString|MULTILINESTRING((0 0,1 1),EMPTY)|f|t
 -#4011|ST_MultiLineString|MULTILINESTRING(EMPTY,EMPTY)|t|t
 -#4011||||
 -#4011|ST_GeometryCollection|POLYGON((0 0,1 0,1 1,0 0))|f|t
 -#4011|ST_LineString|GEOMETRYCOLLECTION(LINESTRING(0 0,1 1))|f|t
 -#4011|ST_MultiLineString|MULTILINESTRING EMPTY|t|t
 -#4011|ST_GeometryCollection|MULTILINESTRING((0 0,0 0))|f|f
 -#4025|
 -ERROR:  lwgeom_intersection: GEOS Error: TopologyException: Input geom 0
 is invalid: Self-intersection
 -ERROR:  lwgeom_difference: GEOS Error: TopologyException: Input geom 0 is
 -ERROR:  lwgeom_symdifference: GEOS Error: TopologyException: Input geom 0
 -ERROR:  lwgeom_union: GEOS Error: TopologyException: Input geom 0 is
 -#4055a|4326
 -#4055b|4326
 -#4089|LINESTRING Z (1 1 1,3 3 1)
 -ERROR:  lwgeom_pointonsurface: GEOS Error: TopologyException: Input geom
 1 is invalid: Self-intersection
 -#4081|f|t
 +server closed the connection unexpectedly
 +       This probably means the server terminated abnormally
 +       before or while processing the request.
 +connection to server was lost
  twkb .. failed (diff expected obtained: /tmp/pgis_reg/test_96_diff)
 --- twkb_expected       2018-08-19 21:46:50.000000000 +0000
 +++ /tmp/pgis_reg/test_96_out   2018-08-20 08:19:44.370425099 +0000
 @@ -1,17 +1 @@
 -POINT(1 1)|01000202
 -POINT(78 -78)|01009c019b01
 -POINT(123.456789 987.654321)|4100f4c0019a870c
 -LINESTRING(120 10, -50 20, 300 -2)|020003f00114d30214bc052b
 -LINESTRING(120 10, -50 20, 300 -2)|420003c0bb01d00fcf8902d00ff0a204af22
 -LINESTRING(120.54 10.78, -50.2 20.878, 300.789
 -21)|020003f20116d50214be0553
 -POLYGON((1 1, 1 2, 2 2, 2 1, 1 1))|0300010502020002020000010100
 -POLYGON((1 1, 1 20, 20 20, 20 1, 1 1),(3 3,3 4, 4 4,4 3,3
 3))|03000205020200262600002525000504040002020000010100
 -MULTIPOINT((1 1),(2 2))|04000202020202
 -MULTILINESTRING((1 1,1 2,2 2),(3 3,3 4,4
 4))|0500020302020002020003020200020200
 -MULTIPOLYGON(((1 1, 1 2, 2 2, 2 1, 1 1)),((3 3,3 4,4 4,4 3,3
 3)))|060002010502020002020000010100010504040002020000010100
 -MULTIPOLYGON(((1 1, 1 20, 20 20, 20 1, 1 1),(3 3,3 4, 4 4,4 3,3 3)),((-1
 1, -1 20, -20 20, -20 1, -1 1),(-3 3,-3 4, -4 4,-4 3,-3
 3)))|06000202050202002626000025250005040400020200000101000205070300262500002526000503040002010000010200
 -GEOMETRYCOLLECTION(POINT(1 1),LINESTRING(2 2,3
 3))|0700020100020202000204040202
 -GEOMETRYCOLLECTION(MULTIPOINT(1 1,2 2),POINT(78 -78),POLYGON((1 1,1 2,2
 2,2 1,1 1)))|0700030400020202020201009c019b010300010502020002020000010100
 -0701000802040201010800020008020201000202040202020104
 -large
 geometry|060001019201aac755e8fea406061b52091c08260f1c08141c0524034c0d12153a211c0f06000e202c011a302e200e0e0702131923102d3e05460d341924071a100e0e121e093804261a02081b002f081f1227141d2015220f5a1d2c09240d0a05010b1b0515060908331645121f1017081f1a1f36150a1f1f00150411120d14150c31161f0417010f170f1d0429220f1a152c100808101820021207141f0e11020903031105270f2f2d370f071113001f1e0b16032211542326021a0c1c0b182f0a290c07220106100a080e0b4e3a0410051a042016161607041107190f230b210735091f091105051d02631c1900170e0b150d3d110927081d0a0f0b1819080f0205030f190f17044d241d12211c19220b14092c134019303304210545012f060504061827380524100e36232205
 +psql: FATAL:  the database system is in recovery mode
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4137#comment:2>
