[postgis-tickets] r16725 - Parse error on incorrectly nested GeoJSON input
Paul Ramsey pramsey at cleverelephant.ca
Mon Sep 10 03:19:00 PDT 2018
Author: pramsey
Date: 2018-09-10 15:19:00 -0700 (Mon, 10 Sep 2018)
New Revision: 16725
   trunk/liblwgeom/cunit/cu_in_geojson.c
   trunk/liblwgeom/lwin_geojson.c
Closes #4164
Modified: trunk/liblwgeom/cunit/cu_in_geojson.c
--- trunk/liblwgeom/cunit/cu_in_geojson.c	2018-09-10 22:18:47 UTC (rev 16724)
+++ trunk/liblwgeom/cunit/cu_in_geojson.c	2018-09-10 22:19:00 UTC (rev 16725)
@@ -151,6 +151,13 @@
 static void in_geojson_test_geoms(void)
+	/* Incorrect Polygon (#4164) */
+	// do_geojson_test(
+	//     "POLYGON((0 0,0 5,5 5,5 0,0 0))",
+	// 	"{\"type\": \"Polygon\", \"coordinates\": [[0,0],[0,5],[5, 5],[5,0],[0,0]]}",
+	// 	NULL);
 	/* Linestring */
 	do_geojson_test(
 	    "LINESTRING(0 1,2 3,4 5)",
Modified: trunk/liblwgeom/lwin_geojson.c
--- trunk/liblwgeom/lwin_geojson.c	2018-09-10 22:18:47 UTC (rev 16724)
+++ trunk/liblwgeom/lwin_geojson.c	2018-09-10 22:19:00 UTC (rev 16725)
@@ -273,7 +273,17 @@
 			json_object* coords = NULL;
 			coords = json_object_array_get_idx( points, j );
-			parse_geojson_coord(coords, hasz, ppa[i]);
+			if (LW_FAILURE == parse_geojson_coord(coords, hasz, ppa[i]))
+				int k;
+				for (k = 0; k <= i; k++)
+					ptarray_free(ppa[k]);
+				lwfree(ppa);
+				geojson_lwerror("The 'coordinates' in GeoJSON polygon are not sufficiently nested", 4);
+				return NULL;
