[postgis-tickets] [PostGIS] #4175: debbie failures on postgis
PostGIS trac at osgeo.org
Tue Sep 11 00:26:43 PDT 2018
  Reporter:  robe       |      Owner:  robe
      Type:  defect     |     Status:  new
  Priority:  blocker    |  Milestone:  PostGIS 2.5.0
 Component:  buildbots  |    Version:  trunk
Resolution:             |   Keywords:
Description changed by robe:
Old description:
> I think debbie's failures in raster, crashing might be due to some
> upstream postgresql changes recently done to all the branches.
> I reverted to tagged 10_5 and the dev run passed.
> Here 2.5 is also failing similarly crashing so need to fix before we
> release 2.5 to see if its something we need to change or need to report
> upstream.
New description:
 upstream.
   /var/lib/jenkins/workspace/postgis/branches/3.0/regress/00-regress-
 install/share/contrib/postgis/rtpostgis_proc_set_search_path.sql
 PostgreSQL 10.5 on x86_64-pc-linux-gnu, compiled by gcc (Debian 8.2.0-5)
 8.2.0, 64-bit
   Postgis 3.0.0dev - r16729 - 2018-09-11 06:20:39
   scripts 3.0.0dev r16729
   raster scripts 3.0.0dev r16729
   GEOS: 3.7.0rc1-CAPI-1.11.0 49f66217
   PROJ: Rel. 5.1.0, June 1st, 2018
   GDAL: GDAL 2.3.1, released 2018/06/22
 Running tests
  check_gdal .. ok
  load_outdb ... ok
  check_raster_columns .. ok
  check_raster_overviews .. ok
  rt_io .. ok
  rt_bytea .. ok
  rt_wkb .. ok
  box3d .. ok
  rt_addband .. ok
  rt_band .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/tmp/3_0_pg10w64/test_10_diff)
 --- rt_band_expected    2018-09-11 06:20:16.310293357 +0000
 +++ /var/lib/jenkins/workspace/postgis/tmp/3_0_pg10w64/test_10_out
 2018-09-11 06:25:52.143617183 +0000
 @@ -12,18 +12,7 @@
  9876.54321
  987.654321
  1234.5678
 -1234.5678
 -1234.5678
 -1234.5678
 -4
 -3
 -2
 -1
 -1
 -1
 -NOTICE:  Invalid band index (must use 1-based). Returning original raster
 -3
 -6|(1,{{7}})
 +psql: FATAL:  the database system is in recovery mode
  rt_valuepercent .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/tmp/3_0_pg10w64/test_37_diff)
 --- rt_valuepercent_expected    2018-09-11 06:20:16.906295708 +0000
 +++ /var/lib/jenkins/workspace/postgis/tmp/3_0_pg10w64/test_37_out
 2018-09-11 06:25:52.435618333 +0000
 @@ -1,35 +1 @@
 --10.000|0.500
 -3.142|0.500
 --10.000|0.500
 -3.142|0.500
 --10.000|0.010
 -0.000|0.980
 -3.142|0.010
 --10.000|0.500
 -3.100|0.500
 -3.100|0.500
 --10.000|0.500
 --10.000|0.500
 --10.000|0.500
 -3.000|0.000
 -0.500
 -0.010
 -0.500
 -0.500
 -0.500
 -0.500
 -BEGIN
 --10.000|0.010
 -0.000|0.980
 -3.142|0.010
 --10.000|0.500
 -1.000|0.000
 --10.000|0.500
 -3.100|0.500
 --1.000|0.000
 -3.100|0.500
 -0.500
 -0.000
 -0.500
 -0.000
 -COMMIT
  rt_bandmetadata .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/tmp/3_0_pg10w64/test_38_diff)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4175#comment:1>
