[postgis-tickets] r16730 - Split a postgis_raster extension out of the postgis one
Sandro Santilli strk at kbt.io
Tue Sep 11 02:18:26 PDT 2018
Author: strk
Date: 2018-09-11 02:18:26 -0700 (Tue, 11 Sep 2018)
New Revision: 16730
Added:
   trunk/extensions/postgis_raster/
   trunk/extensions/postgis_raster/Makefile.in
   trunk/extensions/postgis_raster/postgis_raster.control.in
   trunk/.gitignore
   trunk/configure.ac
   trunk/extensions/Makefile.in
   trunk/extensions/postgis/Makefile.in
   trunk/regress/run_test.pl
Tweaks run_test.pl to create raster extension when needed.
Modified: trunk/.gitignore
--- trunk/.gitignore	2018-09-11 06:19:49 UTC (rev 16729)
+++ trunk/.gitignore	2018-09-11 09:18:26 UTC (rev 16730)
@@ -53,6 +53,8 @@
 extensions/postgis/postgis.control
 extensions/postgis/sql/
 extensions/postgis/sql_bits/*.sql
+extensions/postgis_raster/Makefile
+extensions/postgis_raster/postgis_raster.control
 extensions/postgis_sfcgal/Makefile
 extensions/postgis_sfcgal/postgis_sfcgal.control
 extensions/postgis_sfcgal/sql/
Modified: trunk/configure.ac
--- trunk/configure.ac	2018-09-11 06:19:49 UTC (rev 16729)
+++ trunk/configure.ac	2018-09-11 09:18:26 UTC (rev 16730)
@@ -1453,6 +1453,7 @@
 AC_OUTPUT([GNUmakefile
    extensions/Makefile
+   extensions/postgis_raster/Makefile
    extensions/postgis_topology/Makefile
    extensions/postgis_tiger_geocoder/Makefile
Modified: trunk/extensions/Makefile.in
--- trunk/extensions/Makefile.in	2018-09-11 06:19:49 UTC (rev 16729)
+++ trunk/extensions/Makefile.in	2018-09-11 09:18:26 UTC (rev 16730)
@@ -9,8 +9,11 @@
-SUBDIRS = postgis
-SUBDIRS += postgis_tiger_geocoder
+SUBDIRS = postgis
+SUBDIRS += postgis_tiger_geocoder
+ifeq (@RASTER@,raster)
+	SUBDIRS += postgis_raster
+endif
 ifeq (@TOPOLOGY@,topology)
 	SUBDIRS += postgis_topology
 endif
Modified: trunk/extensions/postgis/Makefile.in
--- trunk/extensions/postgis/Makefile.in	2018-09-11 06:19:49 UTC (rev 16729)
+++ trunk/extensions/postgis/Makefile.in	2018-09-11 09:18:26 UTC (rev 16730)
@@ -34,9 +34,7 @@
 EXTENSION_SCRIPTS = \
 	sql_bits/postgis.sql \
 	sql_bits/postgis_comments.sql \
-	sql_bits/rtpostgis.sql \
 	sql_bits/spatial_ref_sys_config_dump.sql \
-	sql_bits/raster_comments.sql \
 	sql_bits/spatial_ref_sys.sql
 # Scripts making up the extension minor upgrade file
@@ -44,8 +42,6 @@
 EXTENSION_UPGRADE_SCRIPTS = \
 	../postgis_extension_helper.sql \
 	sql_bits/postgis_upgrade.sql \
-	sql_bits/rtpostgis_upgrade.sql \
-	../../doc/raster_comments.sql \
 	../../doc/postgis_comments.sql \
 	../postgis_extension_helper_uninstall.sql
@@ -52,8 +48,7 @@
 # Scripts making up the extension upgrade-from-unpackaged file
 # NOTE: order matters
 EXTENSION_UNPACKAGED_UPGRADE_SCRIPTS = \
-	sql_bits/postgis.sql \
+	sql_bits/postgis.sql
 #DOCS         = $(wildcard ../../doc/html/*.html)
 PG_CONFIG    = @PG_CONFIG@
@@ -111,26 +106,13 @@
 sql_bits/postgis_comments.sql: ../../doc/postgis_comments.sql | sql_bits
 	cp $< $@
-#strip BEGIN/COMMIT since these are not allowed in extensions
-sql_bits/rtpostgis.sql: ../../raster/rt_pg/rtpostgis_for_extension.sql | sql_bits
-	mkdir -p sql
-	$(PERL) -pe 's/BEGIN\;//g ; s/COMMIT\;//g' $< > $@
 sql_bits/spatial_ref_sys_config_dump.sql: ../../spatial_ref_sys.sql ../../utils/create_spatial_ref_sys_config_dump.pl | sql_bits
 	$(PERL) ../../utils/create_spatial_ref_sys_config_dump.pl $< > $@
-sql_bits/rtpostgis_upgrade.sql: ../../raster/rt_pg/rtpostgis_upgrade_for_extension.sql | sql_bits
-	$(PERL) -pe "s/BEGIN\;//g ; s/COMMIT\;//g; s/^(DROP .*)\;/SELECT postgis_extension_drop_if_exists('$(EXTENSION)', '\1');\n\1\;/" $< > $@
 sql_bits/postgis_upgrade.sql: ../../postgis/postgis_upgrade_for_extension.sql | sql_bits
-../../doc/raster_comments.sql:
-	$(MAKE) -C ../../doc comments
-sql_bits/raster_comments.sql: ../../doc/raster_comments.sql | sql_bits
-	cp $< $@
 #postgis_extension_upgrade_minor.sql is the one that contains both postgis AND raster
 sql/$(EXTENSION)--ANY--$(EXTVERSION).sql: $(EXTENSION_UPGRADE_SCRIPTS) | sql
 	printf '\\echo Use "CREATE EXTENSION $(EXTENSION)" to load this file. \\quit\n' > $@
Copied: trunk/extensions/postgis_raster/Makefile.in (from rev 16729, trunk/extensions/postgis/Makefile.in)
--- trunk/extensions/postgis_raster/Makefile.in	                        (rev 0)
+++ trunk/extensions/postgis_raster/Makefile.in	2018-09-11 09:18:26 UTC (rev 16730)
@@ -0,0 +1,130 @@
+include ../upgradeable_versions.mk
+EXTENSION     = postgis_raster
+EXTVERSION    = @POSTGIS_LIB_VERSION@
+MINORVERSION  = @POSTGIS_MAJOR_VERSION at .@POSTGIS_MINOR_VERSION@
+MODULEPATH    = $$libdir/$(EXTENSION)-$(MINORVERSION)
+GREP = @GREP@
+PERL = @PERL@
+MICRO_NUMBER  = $(shell echo $(EXTVERSION) | \
+						$(PERL) -pe 's/\d.\d.(\d+)[a-zA-Z]*\d*/$1/'
+PREREL_NUMBER = $(shell echo $(EXTVERSION) | \
+                        $(PERL) -pe 's/\d\.\d\.(.*)/\1/' | \
+                        $(GREP) "[a-zA-Z]" | \
+                        $(PERL) -pe 's/\d+[a-zA-Z]+(\d+)/\1/'
+MICRO_PREV    = $(shell if test "$(MICRO_NUMBER)x" != "x"; then expr $(MICRO_NUMBER) - 1; fi)
+PREREL_PREV   = $(shell if test "$(PREREL_NUMBER)x" != "x"; then expr $(PREREL_NUMBER) - 1; fi)
+PREREL_PREFIX = $(shell echo $(EXTVERSION) | \
+                        $(PERL) -pe 's/(\d+[a-zA-Z]+)\d*/\1/'
+DATA_built = \
+	$(EXTENSION).control \
+	sql/$(EXTENSION)--$(EXTVERSION).sql \
+	sql/$(EXTENSION)--unpackaged--$(EXTVERSION).sql \
+	$(NULL)
+# Scripts making up the extension file
+# NOTE: order matters
+EXTENSION_SCRIPTS = \
+	sql/rtpostgis.sql \
+	sql/raster_comments.sql
+# Scripts making up the extension minor upgrade file
+EXTENSION_UPGRADE_SCRIPTS = \
+	../postgis_extension_helper.sql \
+	sql/rtpostgis_upgrade.sql \
+	../../doc/raster_comments.sql \
+	../postgis_extension_helper_uninstall.sql
+# Scripts making up the extension upgrade-from-unpackaged file
+EXTENSION_UNPACKAGED_UPGRADE_SCRIPTS = \
+	sql/rtpostgis.sql
+#DOCS         = $(wildcard ../../doc/html/*.html)
+PG_CONFIG    = @PG_CONFIG@
+SQL_BITS     = $(wildcard sql/*.sql)
+EXTRA_CLEAN += ${SQL_BITS} sql/*.sql
+CURV_big=@POSTGIS_MAJOR_VERSION@@POSTGIS_MINOR_VERSION@
+all: sql/$(EXTENSION)--$(EXTVERSION).sql sql/$(EXTENSION)--unpackaged--$(EXTVERSION).sql
+sql/$(EXTENSION).sql: $(EXTENSION_SCRIPTS)
+	mkdir -p sql
+	printf '\\echo Use "CREATE EXTENSION $(EXTENSION)" to load this file. \\quit\n' > $@
+	cat $^ >> $@
+$(EXTENSION).control: $(EXTENSION).control.in Makefile
+	cat $< \
+		| sed -e 's|@EXTVERSION@|$(EXTVERSION)|g' \
+		| sed -e 's|@EXTENSION@|$(EXTENSION)|g' \
+		| sed -e 's|@MODULEPATH@|$(MODULEPATH)|g' \
+sql/$(EXTENSION)--$(EXTVERSION).sql: sql/$(EXTENSION).sql
+	mkdir -p sql
+	cp $< $@
+sql/$(EXTENSION)--unpackaged--$(EXTVERSION).sql: $(EXTENSION_UNPACKAGED_UPGRADE_SCRIPTS) ../../utils/create_unpackaged.pl
+	mkdir -p sql
+	cat $(EXTENSION_UNPACKAGED_UPGRADE_SCRIPTS) | $(PERL) ../../utils/create_unpackaged.pl postgis > $@
+#strip BEGIN/COMMIT since these are not allowed in extensions
+sql/rtpostgis.sql: ../../raster/rt_pg/rtpostgis_for_extension.sql
+	mkdir -p sql
+	$(PERL) -pe 's/BEGIN\;//g ; s/COMMIT\;//g' $< > $@
+sql/rtpostgis_upgrade.sql: ../../raster/rt_pg/rtpostgis_upgrade_for_extension.sql
+	$(PERL) -pe "s/BEGIN\;//g ; s/COMMIT\;//g; s/^(DROP .*)\;/SELECT postgis_extension_drop_if_exists('$(EXTENSION)', '\1');\n\1\;/" $< > $@
+../../doc/raster_comments.sql:
+	$(MAKE) -C ../../doc comments
+sql/raster_comments.sql: ../../doc/raster_comments.sql
+	cp $< $@
+#postgis_extension_upgrade_minor.sql is the one that contains both postgis AND raster
+sql/postgis_extension_upgrade_minor.sql: $(EXTENSION_UPGRADE_SCRIPTS)
+	cat $^ >> $@
+EXTDIR=$(DESTDIR)$(datadir)/$(datamoduledir)
+install: install-upgrade-paths
+# The "next" lines are a cludge to allow upgrading between different
+# revisions of the same version
+install-upgrade-paths: sql/postgis_extension_upgrade_minor.sql
+	tpl='$(EXTENSION)--ANY-$(EXTVERSION).sql'; \
+	ln -fs "$${tpl}" $(EXTDIR)/$(EXTENSION)--$(EXTVERSION)--$(EXTVERSION)next.sql; \
+	ln -fs "$${tpl}" $(EXTDIR)/$(EXTENSION)--$(EXTVERSION)next--$(EXTVERSION).sql; \
+	$(INSTALL_DATA) $^ "$(EXTDIR)/$${tpl}"; \
+	for OLD_VERSION in $(UPGRADEABLE_VERSIONS); do \
+		ln -fs "$${tpl}" $(EXTDIR)/$(EXTENSION)--$$OLD_VERSION--$(EXTVERSION).sql; \
+	done
+uninstall: uninstall-upgrade-paths
+INSTALLED_UPGRADE_SCRIPTS = \
+	$(wildcard $(EXTDIR)/*$(EXTVERSION).sql) \
+	$(wildcard $(EXTDIR)/*$(EXTVERSION)next.sql) \
+	$(NULL)
+uninstall-upgrade-paths:
+	rm -f $(INSTALLED_UPGRADE_SCRIPTS)
+distclean: clean
+	rm -f Makefile
+PGXS := $(shell $(PG_CONFIG) --pgxs)
+include $(PGXS)
+PERL = @PERL@
Added: trunk/extensions/postgis_raster/postgis_raster.control.in
--- trunk/extensions/postgis_raster/postgis_raster.control.in	                        (rev 0)
+++ trunk/extensions/postgis_raster/postgis_raster.control.in	2018-09-11 09:18:26 UTC (rev 16730)
@@ -0,0 +1,5 @@
+# postgis_raster extension
+comment = 'PostGIS raster types and functions'
+default_version = '@EXTVERSION@'
+module_pathname = '@MODULEPATH@'
+relocatable = false
Modified: trunk/regress/run_test.pl
--- trunk/regress/run_test.pl	2018-09-11 06:19:49 UTC (rev 16729)
+++ trunk/regress/run_test.pl	2018-09-11 09:18:26 UTC (rev 16730)
@@ -1317,6 +1317,20 @@
+	if ( $OPT_WITH_RASTER )
+		my $sql = "CREATE EXTENSION postgis_raster";
+		if ( $OPT_UPGRADE_FROM ) {
+			$sql .= " VERSION '" . $OPT_UPGRADE_FROM . "'";
+ 		$cmd = "psql $psql_opts -c \"" . $sql . "\" $DB >> $REGRESS_LOG 2>&1";
+		$rv = system($cmd);
+  	if ( $rv ) {
+  		fail "Error encountered creating EXTENSION POSTGIS_RASTER", $REGRESS_LOG;
+  		die;
 	if ( $OPT_WITH_SFCGAL )
 		do {
@@ -1562,6 +1576,15 @@
         $ok = 0 if $rv;
+        $cmd = "psql $psql_opts -c \"DROP EXTENSION postgis_raster;\" $DB >> $REGRESS_LOG 2>&1";
+        die "\nError encountered dropping EXTENSION POSTGIS_RASTER, see $REGRESS_LOG for details\n\n"
+            if $rv;
+      	$ok = 0 if $rv;
     $cmd = "psql $psql_opts -c \"DROP EXTENSION postgis\" $DB >> $REGRESS_LOG 2>&1";
     $rv = system($cmd);
   	die "\nError encountered dropping EXTENSION POSTGIS, see $REGRESS_LOG for details\n\n"
