[postgis-tickets] r16738 - Only unpackage raster when needed, and hint about restoring it
Sandro Santilli strk at kbt.io
Tue Sep 11 02:19:10 PDT 2018
Author: strk
Date: 2018-09-11 02:19:09 -0700 (Tue, 11 Sep 2018)
New Revision: 16738
Added:
   trunk/extensions/postgis/unpackage_raster_if_needed.sql
   trunk/extensions/postgis/Makefile.in
Modified: trunk/extensions/postgis/Makefile.in
--- trunk/extensions/postgis/Makefile.in	2018-09-11 09:19:03 UTC (rev 16737)
+++ trunk/extensions/postgis/Makefile.in	2018-09-11 09:19:09 UTC (rev 16738)
@@ -41,9 +41,9 @@
 # NOTE: order matters
 EXTENSION_UPGRADE_SCRIPTS = \
 	../postgis_extension_helper.sql \
+	sql/raster_unpackage.sql \
 	sql/postgis_upgrade.sql \
 	../../doc/postgis_comments.sql \
-	sql/raster_unpackage.sql \
 	../postgis_extension_helper_uninstall.sql
 # Scripts making up the extension upgrade-from-unpackaged file
@@ -80,11 +80,16 @@
 $(RASTER_DROP_SCRIPTS):
 	$(MAKE) -C ../../raster
-sql/raster_unpackage.sql: $(RASTER_DROP_SCRIPTS) ../../utils/create_extension_unpackage.pl Makefile | sql
+sql/raster_unpackage.sql: ../../utils/create_extension_unpackage.pl Makefile
+sql/raster_unpackage.sql: $(RASTER_DROP_SCRIPTS) | sql
+	sed '/UNPACKAGE_CODE/q' unpackage_raster_if_needed.sql > $@
 	cat $(RASTER_DROP_SCRIPTS) \
-		| ../../utils/create_extension_unpackage.pl postgis > $@
+		| ../../utils/create_extension_unpackage.pl postgis >> $@
-sql/raster_unpackage.sql: Makefile
+	sed -ne '/UNPACKAGE_CODE/{s///; :a' -e 'n;p;ba' -e '}' \
+		unpackage_raster_if_needed.sql  >> $@
 sql/$(EXTENSION)--$(EXTVERSION).sql: sql/$(EXTENSION).sql | sql
 	cp $< $@
Added: trunk/extensions/postgis/unpackage_raster_if_needed.sql
--- trunk/extensions/postgis/unpackage_raster_if_needed.sql	                        (rev 0)
+++ trunk/extensions/postgis/unpackage_raster_if_needed.sql	2018-09-11 09:19:09 UTC (rev 16738)
@@ -0,0 +1,18 @@
+DO $unpackage_if_needed$
+BEGIN
+	IF EXISTS (
+		select t.typname from pg_depend d, pg_extension e, pg_type t where
+		e.extname = 'postgis' and d.refclassid =
+		'pg_catalog.pg_extension'::pg_catalog.regclass and d.refobjid = e.oid
+		and d.classid = 'pg_type'::regclass and d.objid = t.oid
+		and t.typname = 'raster'
+	) THEN
+		-- UNPACKAGE_CODE --
+		RAISE WARNING 'PostGIS Raster functionality have been unpackaged'
+		USING HINT = 'type `CREATE EXTENSION postgis_raster FROM unpackaged` to re-package';
+	END IF;
+END
+$unpackage_if_needed$ LANGUAGE 'plpgsql';
