[postgis-tickets] r16742 - Fix postgis_raster from unpackaged
Sandro Santilli strk at kbt.io
Tue Sep 11 02:19:31 PDT 2018
Author: strk
Date: 2018-09-11 02:19:31 -0700 (Tue, 11 Sep 2018)
New Revision: 16742
   trunk/extensions/postgis_raster/Makefile.in
Modified: trunk/extensions/postgis_raster/Makefile.in
--- trunk/extensions/postgis_raster/Makefile.in	2018-09-11 09:19:25 UTC (rev 16741)
+++ trunk/extensions/postgis_raster/Makefile.in	2018-09-11 09:19:31 UTC (rev 16742)
@@ -76,7 +76,7 @@
 sql/$(EXTENSION)--unpackaged--$(EXTVERSION).sql: $(EXTENSION_UNPACKAGED_UPGRADE_SCRIPTS) ../../utils/create_unpackaged.pl
 	mkdir -p sql
-	cat $(EXTENSION_UNPACKAGED_UPGRADE_SCRIPTS) | $(PERL) ../../utils/create_unpackaged.pl postgis > $@
+	cat $(EXTENSION_UNPACKAGED_UPGRADE_SCRIPTS) | $(PERL) ../../utils/create_unpackaged.pl postgis_raster > $@
 #strip BEGIN/COMMIT since these are not allowed in extensions
 sql/rtpostgis.sql: ../../raster/rt_pg/rtpostgis_for_extension.sql
@@ -92,7 +92,6 @@
 sql/raster_comments.sql: ../../doc/raster_comments.sql
 	cp $< $@
-#postgis_extension_upgrade_minor.sql is the one that contains both postgis AND raster
 sql/postgis_extension_upgrade_minor.sql: $(EXTENSION_UPGRADE_SCRIPTS)
 	printf '\\echo Use "CREATE EXTENSION $(EXTENSION)" to load this file. \\quit\n' > $@
 	cat $^ >> $@
