[postgis-tickets] r16750 - Also give an hint about dropping raster after upgrade
Sandro Santilli strk at kbt.io
Tue Sep 11 02:20:15 PDT 2018
Author: strk
Date: 2018-09-11 02:20:15 -0700 (Tue, 11 Sep 2018)
New Revision: 16750
   trunk/extensions/postgis/unpackage_raster_if_needed.sql
Modified: trunk/extensions/postgis/unpackage_raster_if_needed.sql
--- trunk/extensions/postgis/unpackage_raster_if_needed.sql	2018-09-11 09:20:09 UTC (rev 16749)
+++ trunk/extensions/postgis/unpackage_raster_if_needed.sql	2018-09-11 09:20:15 UTC (rev 16750)
@@ -15,7 +15,8 @@
 		$unpackage$;
 		RAISE WARNING 'PostGIS Raster functionality have been unpackaged'
-		USING HINT = 'type `CREATE EXTENSION postgis_raster FROM unpackaged` to re-package';
+		USING HINT = 'type `CREATE EXTENSION postgis_raster FROM unpackaged` to re-package'
+								 ' or source `uninstall_rtpostgis.sql` to drop.';
 	END IF;
 END
 $unpackage_if_needed$ LANGUAGE 'plpgsql';
