[postgis-tickets] r16765 - Change warning message
Paul Ramsey pramsey at cleverelephant.ca
Wed Sep 12 09:39:25 PDT 2018
Author: pramsey
Date: 2018-09-12 09:39:24 -0700 (Wed, 12 Sep 2018)
New Revision: 16765
   branches/2.4/configure.ac
Modified: branches/2.4/configure.ac
--- branches/2.4/configure.ac	2018-09-12 16:39:06 UTC (rev 16764)
+++ branches/2.4/configure.ac	2018-09-12 16:39:24 UTC (rev 16765)
@@ -1545,7 +1545,7 @@
 AC_MSG_WARN([ --------- GEOS VERSION WARNING ------------ ])
 AC_MSG_WARN([  You are building against GEOS ${GEOS_FULL_VERSION} ])
 AC_MSG_WARN([  To take advantage of all the features of ])
-AC_MSG_WARN([  this PostGIS version requires GEOS 3.7.0 or higher which is not out yet.])
+AC_MSG_WARN([  this PostGIS version requires GEOS 3.7.0 or higher.])
 AC_MSG_WARN([  To take advantage of most of the features of this PostGIS])
 AC_MSG_WARN([  we recommend GEOS 3.6 or higher])
 AC_MSG_WARN([  You can download the latest versions from ])
