[postgis-tickets] r16768 - [travis] cache pg11 debs
Darafei komzpa at gmail.com
Wed Sep 12 10:30:57 PDT 2018
Author: komzpa
Date: 2018-09-12 10:30:57 -0700 (Wed, 12 Sep 2018)
New Revision: 16768
   trunk/.travis.yml
 - apt --allow-unauthenticated for hiccups with gpg
 - cache Postgres 11 debs on Travis.
Closes https://github.com/postgis/postgis/pull/296
Modified: trunk/.travis.yml
--- trunk/.travis.yml	2018-09-12 17:21:38 UTC (rev 16767)
+++ trunk/.travis.yml	2018-09-12 17:30:57 UTC (rev 16768)
@@ -6,51 +6,46 @@
     - CFLAGS="-g -O0 --coverage -fprofile-arcs -ftest-coverage" LDFLAGS="--coverage -fprofile-arcs -ftest-coverage" CONFIGURE_FLAGS="--enable-debug" PGPORT="5433"
 addons:
-  postgresql: "11"
   apt:
     sources:
-      - sourceline: 'deb https://apt.postgresql.org/pub/repos/apt trusty-pgdg main 11'
+      - sourceline: 'deb http://apt.postgresql.org/pub/repos/apt trusty-pgdg 11'
         key_url: 'https://www.postgresql.org/media/keys/ACCC4CF8.asc'
     packages:
       - eatmydata
-      - postgresql-11
-      - postgresql-server-dev-11
-      - postgresql-11-dbg
-      - libgcc1-dbg
-      - libc++-dev
-      - libc++abi-dev
-      - lib64stdc++6-4.8-dbg
 before_install:
   - eval "${MATRIX_EVAL}"
-  - echo "postgres               soft    core            unlimited" | sudo tee -a /etc/security/limits.conf
-  - echo "postgres               hard    core            unlimited" | sudo tee -a /etc/security/limits.conf
-  - /usr/lib/postgresql/11/bin/pg_config
-  - echo "pg_ctl_options = '-c'" | sudo tee /etc/postgresql/11/main/pg_ctl.conf
   - sudo sh -c "echo /usr/lib/libeatmydata/libeatmydata.so >> /etc/ld.so.preload"
+  - sudo /etc/init.d/postgresql stop
   - curl -sSfL https://github.com/mapbox/logbt/archive/v2.0.3.tar.gz | sudo tar --gunzip --extract --strip-components=1 --exclude="*md" --exclude="test*" --directory=/usr/local
   - curl -sSfL https://raw.githubusercontent.com/mapbox/logbt/30c554dd37b6c96c23fc424f75910fc6d6696f00/bin/logbt | sudo tee /usr/local/bin/logbt > /dev/null
   - sudo logbt --setup
-  - sudo service postgresql status 11
-  - echo "jit = off" | sudo tee -a /etc/postgresql/11/main/postgresql.conf
-  - sudo service postgresql stop 11
-  - sudo chown -hRL --from=postgres travis:travis /etc /var /tmp
-  - sudo usermod -u 1000 postgres
-  - sudo adduser travis ssl-cert
-  - sudo service postgresql start 11
   - sudo add-apt-repository --yes ppa:ubuntugis/ppa
   - sudo add-apt-repository --yes ppa:ubuntugis/ubuntugis-unstable
   - sudo apt-get update -qq
   - mkdir -p /home/travis/deb && touch /home/travis/deb/__ && sudo cp -n /home/travis/deb/* /var/cache/apt/archives || true
-  - sudo apt-get install -y --allow-unauthenticated --no-install-recommends --no-install-suggests libsfcgal1 libsfcgal-dev libxml2-utils libcunit1-dev xsltproc docbook-xsl docbook-mathml dblatex libgeos-dev libjson0-dev libprotobuf-c0-dev libgdal-dev gdb libc6-dbg
+  - sudo apt-get install -y --allow-unauthenticated --no-install-recommends --no-install-suggests postgresql-11 postgresql-server-dev-11 lib64stdc++6-4.8-dbg libc++abi-dev libc++-dev postgresql-11-dbg libgcc1-dbg libsfcgal1 libsfcgal-dev libxml2-utils libcunit1-dev xsltproc docbook-xsl docbook-mathml dblatex libgeos-dev libjson0-dev libprotobuf-c0-dev libgdal-dev gdb libc6-dbg
   - sudo sh -c "echo deb http://archive.ubuntu.com/ubuntu/ artful main restricted universe multiverse >> /etc/apt/sources.list"
   - sudo apt-get install -y --allow-unauthenticated --no-install-recommends --no-install-suggests binutils libproj-dev libprotobuf-c-dev protobuf-c-compiler
   - cp -n /var/cache/apt/archives/* /home/travis/deb || true
-  - ls -la /home/travis/deb/
+  - echo "postgres               soft    core            unlimited" | sudo tee -a /etc/security/limits.conf
+  - echo "postgres               hard    core            unlimited" | sudo tee -a /etc/security/limits.conf
+  - echo "pg_ctl_options = '-c'" | sudo tee /etc/postgresql/11/main/pg_ctl.conf
+  - echo "jit = off" | sudo tee -a /etc/postgresql/11/main/postgresql.conf
+  - sudo service postgresql stop 11
+  - sudo chown -hRL --from=postgres travis:travis /etc /var /tmp
+  - sudo usermod -u 1000 postgres
+  - sudo adduser travis ssl-cert
+  - sudo service postgresql start 11
+  - sudo service postgresql status 11
+  - sudo -u postgres createuser --superuser travis
   - sudo ldconfig
-  - ./autogen.sh
 after_failure:
   - sudo head -n1000 /var/log/postgresql/postgresql-11-main.log
@@ -70,6 +65,7 @@
     - /home/travis/deb
 script:
+  - ./autogen.sh
   - ./configure CFLAGS="$CFLAGS" LDFLAGS="$LDFLAGS" $CONFIGURE_FLAGS || cat config.log
   - make -j
   - chmod 755 /home/travis
