[postgis-tickets] r16776 - Fix Travis GCC warnings
Darafei komzpa at gmail.com
Thu Sep 13 06:48:42 PDT 2018
Author: komzpa
Date: 2018-09-13 06:48:42 -0700 (Thu, 13 Sep 2018)
New Revision: 16776
   trunk/.travis.yml
   trunk/doc/html/image_src/Makefile.in
   trunk/extensions/address_standardizer/pagc_api.h
   trunk/extensions/address_standardizer/tokenize.c
   trunk/liblwgeom/Makefile.in
   trunk/liblwgeom/cunit/Makefile.in
   trunk/liblwgeom/lwhomogenize.c
   trunk/liblwgeom/lwinline.h
   trunk/liblwgeom/lwkmeans.c
   trunk/libpgcommon/Makefile.in
   trunk/loader/Makefile.in
   trunk/loader/cunit/Makefile.in
   trunk/raster/Makefile.in
   trunk/raster/loader/Makefile.in
   trunk/raster/rt_core/Makefile.in
   trunk/raster/rt_pg/rtpg_mapalgebra.c
   trunk/raster/test/cunit/Makefile.in
-Wno-implicit-fallthrough added because of Bison-generated code.
-Wno-unknown-warning-option added because of clang.
-Wno-cast-function-type added because of SFCGAL error printing.
Most other warnings fixed.
Closes https://github.com/postgis/postgis/pull/299
Modified: trunk/.travis.yml
--- trunk/.travis.yml	2018-09-13 13:35:33 UTC (rev 16775)
+++ trunk/.travis.yml	2018-09-13 13:48:42 UTC (rev 16776)
@@ -2,7 +2,7 @@
   matrix:
     - CFLAGS="-g -O1" MATRIX_EVAL="touch check-no-trailing-blanks"
     - CFLAGS="-g -O2 -fstack-protector -Wformat -Werror=format-security" LDFLAGS="-Wl,-Bsymbolic-functions -Wl,-z,relro"
-    - CFLAGS="-g -O3 -mtune=generic -fno-omit-frame-pointer -Werror -Wall -Wextra -Wno-unused-parameter"
+    - CFLAGS="-g -O3 -mtune=generic -fno-omit-frame-pointer -Werror -Wall -Wextra -Wno-unused-parameter -Wno-implicit-fallthrough -Wno-unknown-warning-option -Wno-cast-function-type"
     - CFLAGS="-g -O0 --coverage -fprofile-arcs -ftest-coverage" LDFLAGS="--coverage -fprofile-arcs -ftest-coverage" CONFIGURE_FLAGS="--enable-debug"
 addons:
@@ -17,21 +17,21 @@
   - eval "${MATRIX_EVAL}"
   - sudo sh -c "echo /usr/lib/x86_64-linux-gnu/libeatmydata.so >> /etc/ld.so.preload"
   - sudo service postgresql stop
   - curl -sSfL https://github.com/mapbox/logbt/archive/v2.0.3.tar.gz | sudo tar --gunzip --extract --strip-components=1 --exclude="*md" --exclude="test*" --directory=/usr/local
   - curl -sSfL https://raw.githubusercontent.com/mapbox/logbt/30c554dd37b6c96c23fc424f75910fc6d6696f00/bin/logbt | sudo tee /usr/local/bin/logbt > /dev/null
   - sudo logbt --setup
   - sudo apt-get remove postgresql-9.4 postgresql-9.5 postgresql-9.6 postgresql-10 postgresql-client-9.4 postgresql-client-9.5 postgresql-client-9.6 postgresql-client-10
   - sudo add-apt-repository --yes ppa:ubuntugis/ppa
   - sudo add-apt-repository --yes ppa:ubuntugis/ubuntugis-unstable
-  - sudo sh -c "echo deb http://archive.ubuntu.com/ubuntu/ bionic main restricted universe multiverse >> /etc/apt/sources.list"
+  - sudo sh -c "echo deb http://archive.ubuntu.com/ubuntu/ cosmic main restricted universe multiverse >> /etc/apt/sources.list"
   - sudo apt-get update -qq
   - mkdir -p /home/travis/deb && touch /home/travis/deb/__ && sudo cp -n /home/travis/deb/* /var/cache/apt/archives || true
-  - sudo apt-get install -y --allow-unauthenticated --no-install-recommends --no-install-suggests postgresql-11 postgresql-client-11 postgresql-server-dev-11 postgresql-11-dbgsym libproj-dev libprotobuf-c-dev protobuf-c-compiler libc++abi-dev libc++-dev libgcc1-dbg libsfcgal1 libsfcgal-dev libxml2-utils libcunit1-dev xsltproc docbook-xsl docbook-mathml dblatex libgeos-dev libjson-c-dev libprotobuf-c0-dev libgdal-dev gdb libc6-dbg gcc
+  - sudo apt-get install -y --allow-unauthenticated --no-install-recommends --no-install-suggests postgresql-11 postgresql-client-11 postgresql-server-dev-11 postgresql-11-dbgsym libproj-dev libprotobuf-c-dev protobuf-c-compiler libc++abi-dev libc++-dev libgcc1-dbg libsfcgal1 libsfcgal-dev libxml2-utils libcunit1-dev xsltproc docbook-xsl docbook-mathml dblatex libgeos-dev libjson-c-dev libgdal-dev gdb libc6-dbg gcc
   - cp -n /var/cache/apt/archives/* /home/travis/deb || true
   - echo "postgres               soft    core            unlimited" | sudo tee -a /etc/security/limits.conf
   - echo "postgres               hard    core            unlimited" | sudo tee -a /etc/security/limits.conf
   - echo "pg_ctl_options = '-c'" | sudo tee /etc/postgresql/11/main/pg_ctl.conf
@@ -40,9 +40,9 @@
   - sudo usermod -u 1000 postgres
   - sudo adduser travis ssl-cert
   - sudo service postgresql start
-  - sudo service postgresql status
+  - sudo service postgresql status
   - sudo -u postgres createuser --superuser travis
   - sudo ldconfig
 after_failure:
Modified: trunk/doc/html/image_src/Makefile.in
--- trunk/doc/html/image_src/Makefile.in	2018-09-13 13:35:33 UTC (rev 16775)
+++ trunk/doc/html/image_src/Makefile.in	2018-09-13 13:48:42 UTC (rev 16776)
@@ -10,7 +10,7 @@
 CC=@CC@
-CFLAGS=@CFLAGS@ @WARNFLAGS@ @PROJ_CPPFLAGS@
+CFLAGS=@WARNFLAGS@ @CFLAGS@ @PROJ_CPPFLAGS@
 top_builddir = @top_builddir@
 SHELL = @SHELL@
 LIBTOOL = @LIBTOOL@
Modified: trunk/extensions/address_standardizer/pagc_api.h
--- trunk/extensions/address_standardizer/pagc_api.h	2018-09-13 13:35:33 UTC (rev 16775)
+++ trunk/extensions/address_standardizer/pagc_api.h	2018-09-13 13:48:42 UTC (rev 16776)
@@ -258,7 +258,7 @@
 typedef int NODE ;
 typedef int DEFDEF ;
-#define MAXTEXT 31
+#define MAXTEXT MAXSTRLEN
 #define FIRST_LEX_POS 0
 #define RIGHT_COMPRESS STOPWORD
Modified: trunk/extensions/address_standardizer/tokenize.c
--- trunk/extensions/address_standardizer/tokenize.c	2018-09-13 13:35:33 UTC (rev 16775)
+++ trunk/extensions/address_standardizer/tokenize.c	2018-09-13 13:48:42 UTC (rev 16776)
@@ -979,8 +979,7 @@
        a ;
    BLANK_STRING(Dest) ;
-   strcpy( Dest ,
-           morph_vector[ beg ] . Text ) ;
+   strlcpy(Dest, morph_vector[beg].Text, MAXTEXT);
    for ( i = beg + 1 ;
          i <= end ;
          i++ ) {
Modified: trunk/liblwgeom/Makefile.in
--- trunk/liblwgeom/Makefile.in	2018-09-13 13:35:33 UTC (rev 16775)
+++ trunk/liblwgeom/Makefile.in	2018-09-13 13:48:42 UTC (rev 16776)
@@ -24,7 +24,7 @@
 CC = @CC@
 CPPFLAGS = @CPPFLAGS@
-CFLAGS = @CFLAGS@ @PICFLAGS@ @WARNFLAGS@ @GEOS_CPPFLAGS@ @PROJ_CPPFLAGS@ @JSON_CPPFLAGS@
+CFLAGS = @WARNFLAGS@ @CFLAGS@ @PICFLAGS@ @GEOS_CPPFLAGS@ @PROJ_CPPFLAGS@ @JSON_CPPFLAGS@
 LDFLAGS = @LDFLAGS@ @GEOS_LDFLAGS@ -lgeos_c @PROJ_LDFLAGS@ -lproj @JSON_LDFLAGS@ -lm
 NUMERICFLAGS = @NUMERICFLAGS@
Modified: trunk/liblwgeom/cunit/Makefile.in
--- trunk/liblwgeom/cunit/Makefile.in	2018-09-13 13:35:33 UTC (rev 16775)
+++ trunk/liblwgeom/cunit/Makefile.in	2018-09-13 13:48:42 UTC (rev 16776)
@@ -17,7 +17,7 @@
 CUNIT_LDFLAGS=@CUNIT_LDFLAGS@
 CUNIT_CPPFLAGS=@CUNIT_CPPFLAGS@ -I..
-CFLAGS=@CFLAGS@ @WARNFLAGS@ @GEOS_CPPFLAGS@ @PROJ_CPPFLAGS@ $(CUNIT_CPPFLAGS)
+CFLAGS=@WARNFLAGS@ @CFLAGS@ @GEOS_CPPFLAGS@ @PROJ_CPPFLAGS@ $(CUNIT_CPPFLAGS)
 LDFLAGS = @GEOS_LDFLAGS@ -lgeos_c $(CUNIT_LDFLAGS) -lm
 # ADD YOUR NEW TEST FILE HERE (1/1)
Modified: trunk/liblwgeom/lwhomogenize.c
--- trunk/liblwgeom/lwhomogenize.c	2018-09-13 13:35:33 UTC (rev 16775)
+++ trunk/liblwgeom/lwhomogenize.c	2018-09-13 13:48:42 UTC (rev 16776)
@@ -77,42 +77,39 @@
 	uint32_t i;
-	if ( ! col ) return;
-	if ( lwgeom_is_empty(lwcollection_as_lwgeom(col)) ) return;
-	for ( i = 0; i < col->ngeoms; i++ )
+	if (!col || lwcollection_is_empty(col))
+		return;
+	for (i = 0; i < col->ngeoms; i++)
 		LWGEOM *geom = col->geoms[i];
-		switch(geom->type)
+		switch (geom->type)
-			case POINTTYPE:
-			case LINETYPE:
-			case CIRCSTRINGTYPE:
-			case COMPOUNDTYPE:
-			case TRIANGLETYPE:
-			case CURVEPOLYTYPE:
-			case POLYGONTYPE:
+		case POINTTYPE:
+		case LINETYPE:
+		case CIRCSTRINGTYPE:
+		case COMPOUNDTYPE:
+		case TRIANGLETYPE:
+		case CURVEPOLYTYPE:
+		case POLYGONTYPE:
+			/* Init if necessary */
+			if (!buffer->buf[geom->type])
-				/* Init if necessary */
-				if ( ! buffer->buf[geom->type] )
-					LWCOLLECTION *bufcol = lwcollection_construct_empty(COLLECTIONTYPE, col->srid, FLAGS_GET_Z(col->flags), FLAGS_GET_M(col->flags));
-					bufcol->type = lwtype_get_collectiontype(geom->type);
-					buffer->buf[geom->type] = bufcol;
-				/* Add sub-geom to buffer */
-				lwcollection_add_lwgeom(buffer->buf[geom->type], lwgeom_clone(geom));
-				/* Increment count for this singleton type */
-				buffer->cnt[geom->type] = buffer->cnt[geom->type] + 1;
+				LWCOLLECTION *bufcol = lwcollection_construct_empty(
+				    COLLECTIONTYPE, col->srid, FLAGS_GET_Z(col->flags), FLAGS_GET_M(col->flags));
+				bufcol->type = lwtype_get_collectiontype(geom->type);
+				buffer->buf[geom->type] = bufcol;
-			/* FALLTHROUGH */
-			default:
-				lwcollection_build_buffer(lwgeom_as_lwcollection(geom), buffer);
-				break;
+			/* Add sub-geom to buffer */
+			lwcollection_add_lwgeom(buffer->buf[geom->type], lwgeom_clone(geom));
+			/* Increment count for this singleton type */
+			buffer->cnt[geom->type]++;
+			break;
+		default:
+			lwcollection_build_buffer(lwgeom_as_lwcollection(geom), buffer);
+			break;
-	return;
 static LWGEOM*
Modified: trunk/liblwgeom/lwinline.h
--- trunk/liblwgeom/lwinline.h	2018-09-13 13:35:33 UTC (rev 16775)
+++ trunk/liblwgeom/lwinline.h	2018-09-13 13:48:42 UTC (rev 16776)
@@ -121,41 +121,31 @@
 static inline int
 lwpoint_is_empty(const LWPOINT *point)
-	if (!point->point || point->point->npoints < 1)
-		return LW_TRUE;
-	return LW_FALSE;
+	return !point->point || point->point->npoints < 1;
 static inline int
 lwline_is_empty(const LWLINE *line)
-	if (!line->points || line->points->npoints < 1)
-		return LW_TRUE;
-	return LW_FALSE;
+	return !line->points || line->points->npoints < 1;
 static inline int
 lwcircstring_is_empty(const LWCIRCSTRING *circ)
-	if (!circ->points || circ->points->npoints < 1)
-		return LW_TRUE;
-	return LW_FALSE;
+	return !circ->points || circ->points->npoints < 1;
 static inline int
 lwpoly_is_empty(const LWPOLY *poly)
-	if ((poly->nrings < 1) || (!poly->rings) || (!poly->rings[0]) || (poly->rings[0]->npoints < 1))
-		return LW_TRUE;
-	return LW_FALSE;
+	return poly->nrings < 1 || !poly->rings || !poly->rings[0] || poly->rings[0]->npoints < 1;
 static inline int
 lwtriangle_is_empty(const LWTRIANGLE *triangle)
-	if (!triangle->points || triangle->points->npoints < 1)
-		return LW_TRUE;
-	return LW_FALSE;
+	return !triangle->points || triangle->points->npoints < 1;
 static inline int lwgeom_is_empty(const LWGEOM *geom);
@@ -164,7 +154,7 @@
 lwcollection_is_empty(const LWCOLLECTION *col)
 	uint32_t i;
-	if ((col->ngeoms == 0) || (!col->geoms))
+	if (col->ngeoms == 0 || !col->geoms)
 		return LW_TRUE;
Modified: trunk/liblwgeom/lwkmeans.c
--- trunk/liblwgeom/lwkmeans.c	2018-09-13 13:35:33 UTC (rev 16775)
+++ trunk/liblwgeom/lwkmeans.c	2018-09-13 13:48:42 UTC (rev 16776)
@@ -123,7 +123,7 @@
 static void
-kmeans_init(POINT2D** objs, int* clusters, uint32_t n, POINT2D** centers, POINT2D* centers_raw, uint32_t k)
+kmeans_init(POINT2D **objs, uint32_t n, POINT2D **centers, POINT2D *centers_raw, uint32_t k)
 	double* distances;
 	uint32_t p1 = 0, p2 = 0;
@@ -327,12 +327,12 @@
 	if (k > 1)
-		kmeans_init(objs, clusters, n, centers, centers_raw, k);
+		kmeans_init(objs, n, centers, centers_raw, k);
 		result = kmeans(objs, clusters, n, centers, k);
 	else
-		/* k=0: everythong is unclusterable
+		/* k=0: everything is unclusterable
 		 * k=1: mark up NULL and non-NULL */
 		for (i = 0; i < n; i++)
Modified: trunk/libpgcommon/Makefile.in
--- trunk/libpgcommon/Makefile.in	2018-09-13 13:35:33 UTC (rev 16775)
+++ trunk/libpgcommon/Makefile.in	2018-09-13 13:48:42 UTC (rev 16776)
@@ -10,7 +10,7 @@
 CC=@CC@
-CFLAGS=-I../liblwgeom @CFLAGS@ @PGSQL_BE_CPPFLAGS@ @PROJ_CPPFLAGS@ @PICFLAGS@ @WARNFLAGS@ @GETTEXT_CFLAGS@
+CFLAGS=-I../liblwgeom @WARNFLAGS@ @CFLAGS@ @PGSQL_BE_CPPFLAGS@ @PROJ_CPPFLAGS@ @PICFLAGS@ @GETTEXT_CFLAGS@
 LDFLAGS=@GETTEXT_LDFLAGS@ @LIBINTL@
 NUMERICFLAGS=@NUMERICFLAGS@
@@ -39,15 +39,15 @@
 install uninstall:
 libpgcommon.a: $(SA_OBJS) $(SA_HEADERS)
-	ar rs libpgcommon.a $(SA_OBJS)
+	ar rs libpgcommon.a $(SA_OBJS)
 maintainer-clean: clean
-clean:
+clean:
 	$(MAKE) -C cunit clean
-	rm -f $(SA_OBJS)
-	rm -f $(NM_OBJS)
-	rm -f libpgcommon.a
+	rm -f $(SA_OBJS)
+	rm -f $(NM_OBJS)
+	rm -f libpgcommon.a
 distclean: clean
 	$(MAKE) -C cunit distclean
@@ -57,7 +57,7 @@
 	$(MAKE) -C cunit check
 # Command to build each of the .o files
-$(SA_OBJS): %.o: %.c
+$(SA_OBJS): %.o: %.c
 	$(CC) $(CFLAGS) -c -o $@ $<
 $(SA_OBJS): ../postgis_config.h
Modified: trunk/loader/Makefile.in
--- trunk/loader/Makefile.in	2018-09-13 13:35:33 UTC (rev 16775)
+++ trunk/loader/Makefile.in	2018-09-13 13:48:42 UTC (rev 16776)
@@ -22,7 +22,7 @@
 # Set CFLAGS afer PGXS, otherwise it will get overwritten with the PGXS
 # version which is not what we want.
 CC=@CC@
-CFLAGS=-I ../liblwgeom @CFLAGS@ @PICFLAGS@ @WARNFLAGS@ @PROJ_CPPFLAGS@
+CFLAGS=-I ../liblwgeom @WARNFLAGS@ @CFLAGS@ @PICFLAGS@ @PROJ_CPPFLAGS@
 SHELL = @SHELL@
 INSTALL = @INSTALL@
Modified: trunk/loader/cunit/Makefile.in
--- trunk/loader/cunit/Makefile.in	2018-09-13 13:35:33 UTC (rev 16775)
+++ trunk/loader/cunit/Makefile.in	2018-09-13 13:48:42 UTC (rev 16776)
@@ -11,7 +11,7 @@
 CC=@CC@
 SHELL = @SHELL@
 LIBTOOL = @LIBTOOL@
@@ -78,7 +78,7 @@
 endif
 # Build the main unit test executable
-cu_tester: $(LOADER_OBJS) $(OBJS)
+cu_tester: $(LOADER_OBJS) $(OBJS)
 	$(LIBTOOL) --mode=link \
 	$(CC)  $^ -o $@ $(LIBLWGEOM) $(LDFLAGS)
Modified: trunk/raster/Makefile.in
--- trunk/raster/Makefile.in	2018-09-13 13:35:33 UTC (rev 16775)
+++ trunk/raster/Makefile.in	2018-09-13 13:48:42 UTC (rev 16776)
@@ -20,7 +20,7 @@
 CC=@CC@
-CFLAGS=-I../liblwgeom @CFLAGS@ @WARNFLAGS@
 LDFLAGS = @LDFLAGS@
 all: @RT_CORE_LIB@ @RT_PG_LIB@ @RT_LOADER@ @RT_POSTGIS_SQL@
Modified: trunk/raster/loader/Makefile.in
--- trunk/raster/loader/Makefile.in	2018-09-13 13:35:33 UTC (rev 16775)
+++ trunk/raster/loader/Makefile.in	2018-09-13 13:48:42 UTC (rev 16776)
@@ -57,7 +57,7 @@
 ICONV_CFLAGS=@ICONV_CFLAGS@
 CFLAGS = \
-	@CFLAGS@ @PICFLAGS@ @WARNFLAGS@ \
+	@WARNFLAGS@ @CFLAGS@ @PICFLAGS@ \
 	$(RTCORE_CFLAGS) \
 	$(LIBLWGEOM_CFLAGS) \
 	$(PROJ_CFLAGS) \
Modified: trunk/raster/rt_core/Makefile.in
--- trunk/raster/rt_core/Makefile.in	2018-09-13 13:35:33 UTC (rev 16775)
+++ trunk/raster/rt_core/Makefile.in	2018-09-13 13:48:42 UTC (rev 16776)
@@ -28,7 +28,7 @@
 GEOS_LDFLAGS = @GEOS_LDFLAGS@ -lgeos_c
 PROJ_LDFLAGS = @PROJ_LDFLAGS@ -lproj
 LDFLAGS = $(LIBLWGEOM_LDFLAGS) $(LIBGDAL_LDFLAGS) $(PROJ_LDFLAGS) $(GEOS_LDFLAGS)
-CFLAGS = $(LIBLWGEOM_CFLAGS) @CFLAGS@ @PICFLAGS@ @WARNFLAGS@ $(LIBGDAL_CFLAGS) @PROJ_CPPFLAGS@ @GEOS_CPPFLAGS@
+CFLAGS = $(LIBLWGEOM_CFLAGS) @WARNFLAGS@ @CFLAGS@ @PICFLAGS@ $(LIBGDAL_CFLAGS) @PROJ_CPPFLAGS@ @GEOS_CPPFLAGS@
 # Standalone RTCORE objects
 RT_OBJS = \
Modified: trunk/raster/rt_pg/rtpg_mapalgebra.c
--- trunk/raster/rt_pg/rtpg_mapalgebra.c	2018-09-13 13:35:33 UTC (rev 16775)
+++ trunk/raster/rt_pg/rtpg_mapalgebra.c	2018-09-13 13:48:42 UTC (rev 16776)
@@ -6369,6 +6369,7 @@
 	switch (extenttype) {
 		case ET_FIRST:
 			i = 0;
+			/* fall through */
 		case ET_SECOND:
 			if (i > 1)
 				i = 1;
Modified: trunk/raster/test/cunit/Makefile.in
--- trunk/raster/test/cunit/Makefile.in	2018-09-13 13:35:33 UTC (rev 16775)
+++ trunk/raster/test/cunit/Makefile.in	2018-09-13 13:48:42 UTC (rev 16776)
@@ -30,7 +30,7 @@
 CC=@CC@
 CFLAGS = \
-	@CFLAGS@ @WARNFLAGS@ \
+	@WARNFLAGS@ @CFLAGS@ \
 	$(RTCORE_CFLAGS) \
 	$(PROJ_CFLAGS) \
@@ -62,7 +62,7 @@
 	cu_spatial_relationship.o \
 	cu_mapalgebra.o \
 	cu_misc.o \
-	cu_tester.o
+	cu_tester.o
 # If we couldn't find the cunit library then display a helpful message
 ifeq ($(CUNIT_LDFLAGS),)
