[postgis-tickets] [PostGIS] #2985: server crash when analyzing small tables on FreeBSD Ports
PostGIS trac at osgeo.org
Thu Sep 13 09:07:51 PDT 2018
  Reporter:  nkiraly   |      Owner:  pramsey
      Type:  defect    |     Status:  reopened
  Priority:  critical  |  Milestone:  PostGIS Packaging
 Component:  postgis   |    Version:  2.2.x
Resolution:            |   Keywords:  analyze server crash freebsd
Comment (by komzpa):
 Reproduced on Travis after #4177 patch applied (3 of 4 jobs failed, one
 survived somehow):
 https://travis-ci.org/postgis/postgis/builds/428202858
 [logbt] saw 'make' exit with code:2 (INT)
 [logbt] Found corefile (non-tracked) at /tmp/logbt-
 coredumps/core.1192.!usr!lib!postgresql!11!bin!postgres
 [logbt] Processing cores...
 [New LWP 1192]
 [Thread debugging using libthread_db enabled]
 Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
 Core was generated by `postgres: 11/main: travis postgis_reg [local]
 ANALYZE                         '.
 Program terminated with signal SIGABRT, Aborted.
 #0  __GI_raise (sig=sig at entry=6) at ../sysdeps/unix/sysv/linux/raise.c:50
 50      ../sysdeps/unix/sysv/linux/raise.c: No such file or directory.
 Thread 1 (Thread 0x7f4e9c8a8b00 (LWP 1192)):
 #1  0x00007f4ea42a3535 in __GI_abort () at abort.c:79
 #2  0x00007f4ea430a516 in __libc_message (action=action at entry=do_abort,
 fmt=fmt at entry=0x7f4ea442e9ee "*** %s ***: %s terminated\n") at
 ../sysdeps/posix/libc_fatal.c:181
 #3  0x00007f4ea43ae431 in __GI___fortify_fail_abort
 (need_backtrace=need_backtrace at entry=false, msg=msg at entry=0x7f4ea442e9cc
 "stack smashing detected") at fortify_fail.c:33
 #4  0x00007f4ea43ae3f2 in __stack_chk_fail () at stack_chk_fail.c:29
 #5  0x00007f4e9291d8d8 in compute_gserialized_stats_mode
 (stats=stats at entry=0x562e82128780,
 fetchfunc=fetchfunc at entry=0x562e808c6970 <std_fetch_func>,
 sample_rows=sample_rows at entry=1, total_rows=total_rows at entry=1,
 mode=mode at entry=2) at gserialized_estimate.c:1755
 #6  0x00007f4e9291d8fd in compute_gserialized_stats (stats=0x562e82128780,
 fetchfunc=0x562e808c6970 <std_fetch_func>, sample_rows=1, total_rows=1) at
 gserialized_estimate.c:1841
 #7  0x0000562e808c9071 in do_analyze_rel
 (onerel=onerel at entry=0x562e8235d400, options=options at entry=2,
 params=params at entry=0x7ffd6d3e6fa0, va_cols=va_cols at entry=0x0,
 acquirefunc=<optimized out>, relpages=1, inh=false, in_outer_xact=false,
 elevel=13) at ./build/../src/backend/commands/analyze.c:579
 #8  0x0000562e808ca6fc in analyze_rel (relid=18637,
 relation=0x562e81524738, options=options at entry=2,
 params=params at entry=0x7ffd6d3e6fa0, va_cols=0x0, in_outer_xact=<optimized
 out>, bstrategy=0x562e817ba610) at
 ./build/../src/backend/commands/analyze.c:310
 #9  0x0000562e80938f25 in vacuum (options=2, relations=0x562e817ba770,
 params=params at entry=0x7ffd6d3e6fa0, bstrategy=<optimized out>,
 bstrategy at entry=0x0, isTopLevel=isTopLevel at entry=true) at
 ./build/../src/backend/commands/vacuum.c:357
 #10 0x0000562e80939290 in ExecVacuum
 (vacstmt=vacstmt at entry=0x562e81524808, isTopLevel=isTopLevel at entry=true)
 at ./build/../src/backend/commands/vacuum.c:141
 #11 0x0000562e80a9ea60 in standard_ProcessUtility (pstmt=0x562e815248a8,
 queryString=0x562e81523d40 "ANALYZE test_analyze_crash;",
 context=<optimized out>, params=0x0, queryEnv=0x0, dest=0x562e81524b68,
 completionTag=0x7ffd6d3e72e0 "") at
 ./build/../src/backend/tcop/utility.c:667
 #12 0x0000562e80a9b6e9 in PortalRunUtility (portal=0x562e815a9880,
 pstmt=0x562e815248a8, isTopLevel=<optimized out>,
 setHoldSnapshot=<optimized out>, dest=<optimized out>,
 ./build/../src/backend/tcop/pquery.c:1178
 #13 0x0000562e80a9c1e7 in PortalRunMulti
 (portal=portal at entry=0x562e815a9880, isTopLevel=isTopLevel at entry=true,
 setHoldSnapshot=setHoldSnapshot at entry=false,
 dest=dest at entry=0x562e81524b68, altdest=altdest at entry=0x562e81524b68,
 completionTag=completionTag at entry=0x7ffd6d3e72e0 "") at
 ./build/../src/backend/tcop/pquery.c:1331
 #14 0x0000562e80a9ce8e in PortalRun (portal=portal at entry=0x562e815a9880,
 count=count at entry=9223372036854775807, isTopLevel=isTopLevel at entry=true,
 run_once=run_once at entry=true, dest=dest at entry=0x562e81524b68,
 altdest=altdest at entry=0x562e81524b68, completionTag=0x7ffd6d3e72e0 "") at
 ./build/../src/backend/tcop/pquery.c:799
 #15 0x0000562e80a98b27 in exec_simple_query (query_string=0x562e81523d40
 "ANALYZE test_analyze_crash;") at
 ./build/../src/backend/tcop/postgres.c:1122
 #16 0x0000562e80a9ab36 in PostgresMain (argc=<optimized out>,
 argv=argv at entry=0x562e8156de78, dbname=<optimized out>,
 username=<optimized out>) at ./build/../src/backend/tcop/postgres.c:4153
 #17 0x0000562e80a25bed in BackendRun (port=0x562e81567250) at
 ./build/../src/backend/postmaster/postmaster.c:4361
 #18 BackendStartup (port=0x562e81567250) at
 ./build/../src/backend/postmaster/postmaster.c:4033
 #19 ServerLoop () at ./build/../src/backend/postmaster/postmaster.c:1706
 #20 0x0000562e80a26c2f in PostmasterMain (argc=5, argv=0x562e8151e870) at
 ./build/../src/backend/postmaster/postmaster.c:1379
 #21 0x0000562e807b3cdb in main (argc=5, argv=0x562e8151e870) at
 ./build/../src/backend/main/main.c:228
 travis_time:end:1c2705c6:start=1536850966762588593,finish=1536851027772766991,duration=61010178398
 [0K
 [31;1mThe command "logbt -- make check "RUNTESTFLAGS=--verbose"" exited
 with 2.[0m
Ticket URL: <https://trac.osgeo.org/postgis/ticket/2985#comment:47>
