[postgis-tickets] r16780 - Postgres 12 disallows variable length arrays in C, raster part
Darafei komzpa at gmail.com
Thu Sep 13 10:25:51 PDT 2018
Author: komzpa
Date: 2018-09-13 10:25:51 -0700 (Thu, 13 Sep 2018)
New Revision: 16780
   trunk/raster/rt_pg/rtpg_band_properties.c
   trunk/raster/rt_pg/rtpg_gdal.c
   trunk/raster/rt_pg/rtpg_geometry.c
   trunk/raster/rt_pg/rtpg_mapalgebra.c
   trunk/raster/rt_pg/rtpg_pixel.c
   trunk/raster/rt_pg/rtpg_raster_properties.c
   trunk/raster/rt_pg/rtpg_statistics.c
Patch by Laurenz Albe
Closes #4177
Modified: trunk/raster/rt_pg/rtpg_band_properties.c
--- trunk/raster/rt_pg/rtpg_band_properties.c	2018-09-13 17:25:17 UTC (rev 16779)
+++ trunk/raster/rt_pg/rtpg_band_properties.c	2018-09-13 17:25:51 UTC (rev 16780)
@@ -464,6 +464,8 @@
     PG_RETURN_INT64(fileSize);
+#define VALUES_LENGTH 8
  * Get raster bands' meta data
@@ -711,11 +713,10 @@
 	/* do when there is more left to send */
 	if (call_cntr < max_calls) {
-		int values_length = 8;
-		Datum values[values_length];
-		bool nulls[values_length];
+		Datum values[VALUES_LENGTH];
+		bool nulls[VALUES_LENGTH];
-		memset(nulls, FALSE, sizeof(bool) * values_length);
+		memset(nulls, FALSE, sizeof(bool) * VALUES_LENGTH);
 		values[0] = UInt32GetDatum(bmd2[call_cntr].bandnum);
 		values[1] = CStringGetTextDatum(bmd2[call_cntr].pixeltype);
Modified: trunk/raster/rt_pg/rtpg_gdal.c
--- trunk/raster/rt_pg/rtpg_gdal.c	2018-09-13 17:25:17 UTC (rev 16779)
+++ trunk/raster/rt_pg/rtpg_gdal.c	2018-09-13 17:25:51 UTC (rev 16780)
@@ -330,6 +330,8 @@
 	PG_RETURN_POINTER(result);
+#define VALUES_LENGTH 6
  * Returns available GDAL drivers
@@ -396,15 +398,14 @@
-		int values_length = 6;
 		HeapTuple tuple;
 		Datum result;
 		POSTGIS_RT_DEBUGF(3, "Result %d", call_cntr);
 		values[0] = Int32GetDatum(drv_set2[call_cntr].idx);
 		values[1] = CStringGetTextDatum(drv_set2[call_cntr].short_name);
Modified: trunk/raster/rt_pg/rtpg_geometry.c
--- trunk/raster/rt_pg/rtpg_geometry.c	2018-09-13 17:25:17 UTC (rev 16779)
+++ trunk/raster/rt_pg/rtpg_geometry.c	2018-09-13 17:25:51 UTC (rev 16780)
@@ -188,6 +188,8 @@
 	PG_RETURN_POINTER(gser);
+#define VALUES_LENGTH 2
 PG_FUNCTION_INFO_V1(RASTER_dumpAsPolygons);
 Datum RASTER_dumpAsPolygons(PG_FUNCTION_ARGS) {
 	FuncCallContext *funcctx;
@@ -309,9 +311,8 @@
-		int values_length = 2;
 		HeapTuple    tuple;
 		Datum        result;
@@ -320,7 +321,7 @@
 		POSTGIS_RT_DEBUGF(3, "call number %d", call_cntr);
 		/* convert LWGEOM to GSERIALIZED */
 		gser = gserialized_from_lwgeom(lwpoly_as_lwgeom(geomval2[call_cntr].geom), &gser_size);
@@ -344,6 +345,9 @@
+#undef VALUES_LENGTH
+#define VALUES_LENGTH 4
  * Return the geographical shape of all pixels
@@ -611,9 +615,8 @@
-		int values_length = 4;
 		HeapTuple tuple;
 		Datum result;
@@ -622,7 +625,7 @@
 		gser = gserialized_from_lwgeom(pix2[call_cntr].geom, &gser_size);
Modified: trunk/raster/rt_pg/rtpg_mapalgebra.c
--- trunk/raster/rt_pg/rtpg_mapalgebra.c	2018-09-13 17:25:17 UTC (rev 16779)
+++ trunk/raster/rt_pg/rtpg_mapalgebra.c	2018-09-13 17:25:51 UTC (rev 16780)
@@ -6068,6 +6068,8 @@
     PG_RETURN_POINTER(pgrtn);
+#define ARGKWCOUNT 8
  * Two raster MapAlgebra
@@ -6115,11 +6117,10 @@
 	SPIPlanPtr spi_plan[3] = {NULL};
 	uint16_t spi_empty = 0;
 	Oid *argtype = NULL;
-	const uint32_t argkwcount = 8;
 	uint8_t argpos[3][8] = {{0}};
 	char *argkw[] = {"[rast1.x]", "[rast1.y]", "[rast1.val]", "[rast1]", "[rast2.x]", "[rast2.y]", "[rast2.val]", "[rast2]"};
-	Datum values[argkwcount];
-	char nulls[argkwcount];
+	Datum values[ARGKWCOUNT];
+	char nulls[ARGKWCOUNT];
 	TupleDesc tupdesc;
 	SPITupleTable *tuptable = NULL;
 	HeapTuple tuple;
@@ -6639,7 +6640,7 @@
 					expr = text_to_cstring(PG_GETARG_TEXT_P(spi_exprpos[i]));
 					POSTGIS_RT_DEBUGF(3, "raw expr #%d: %s", i, expr);
-					for (j = 0, k = 1; j < argkwcount; j++) {
+					for (j = 0, k = 1; j < ARGKWCOUNT; j++) {
 						/* attempt to replace keyword with placeholder */
 						len = 0;
 						tmp = rtpg_strreplace(expr, argkw[j], place, &len);
@@ -6704,7 +6705,7 @@
 						/* specify datatypes of parameters */
-						for (j = 0, k = 0; j < argkwcount; j++) {
+						for (j = 0, k = 0; j < ARGKWCOUNT; j++) {
 							if (argpos[i][j] < 1) continue;
 							/* positions are INT4 */
@@ -7003,14 +7004,14 @@
 							POSTGIS_RT_DEBUGF(4, "Using prepared plan: %d", i);
 							/* reset values to (Datum) NULL */
-							memset(values, (Datum) NULL, sizeof(Datum) * argkwcount);
+							memset(values, (Datum) NULL, sizeof(Datum) * ARGKWCOUNT);
 							/* reset nulls to FALSE */
-							memset(nulls, FALSE, sizeof(char) * argkwcount);
+							memset(nulls, FALSE, sizeof(char) * ARGKWCOUNT);
 							/* expression has argument(s) */
 							if (spi_argcount[i]) {
 								/* set values and nulls */
-								for (j = 0; j < argkwcount; j++) {
+								for (j = 0; j < ARGKWCOUNT; j++) {
 									idx = argpos[i][j];
 									if (idx < 1) continue;
 									idx--; /* 1-based becomes 0-based */
Modified: trunk/raster/rt_pg/rtpg_pixel.c
--- trunk/raster/rt_pg/rtpg_pixel.c	2018-09-13 17:25:17 UTC (rev 16779)
+++ trunk/raster/rt_pg/rtpg_pixel.c	2018-09-13 17:25:51 UTC (rev 16780)
@@ -197,6 +197,8 @@
 	pfree(arg);
 PG_FUNCTION_INFO_V1(RASTER_dumpValues);
 Datum RASTER_dumpValues(PG_FUNCTION_ARGS)
@@ -514,9 +516,8 @@
 		HeapTuple tuple;
 		Datum result;
 		ArrayType *mdValues = NULL;
@@ -527,7 +528,7 @@
 		POSTGIS_RT_DEBUGF(4, "dim = %d, %d", dim[0], dim[1]);
 		values[0] = Int32GetDatum(arg2->nbands[call_cntr] + 1);
@@ -1601,6 +1602,9 @@
+#define VALUES_LENGTH 3
  * Get pixels of value
@@ -1799,13 +1803,12 @@
-		int values_length = 3;
 		HeapTuple tuple;
 		Datum result;
 		/* 0-based to 1-based */
 		pixels2[call_cntr].x += 1;
Modified: trunk/raster/rt_pg/rtpg_raster_properties.c
--- trunk/raster/rt_pg/rtpg_raster_properties.c	2018-09-13 17:25:17 UTC (rev 16779)
+++ trunk/raster/rt_pg/rtpg_raster_properties.c	2018-09-13 17:25:51 UTC (rev 16780)
@@ -429,6 +429,8 @@
     PG_RETURN_FLOAT8(pheight);
  * Calculates the physically relevant parameters of the supplied raster's
  * geotransform. Returns them as a set.
@@ -449,9 +451,8 @@
     TupleDesc result_tuple; /* for returning a composite */
     HeapTuple heap_tuple ;   /* instance of the tuple to return */
     Datum result;
@@ -503,7 +504,7 @@
     values[4] = Float8GetDatum(rt_raster_get_x_offset(raster));
     values[5] = Float8GetDatum(rt_raster_get_y_offset(raster));
     /* stick em on the heap */
     heap_tuple = heap_form_tuple(result_tuple, values, nulls);
@@ -581,6 +582,9 @@
     PG_RETURN_BOOL(hasnoband);
+#define VALUES_LENGTH 10
  * Get raster's meta data
@@ -602,9 +606,8 @@
 	uint32_t height;
 	TupleDesc tupdesc;
-	int values_length = 10;
 	HeapTuple tuple;
 	Datum result;
@@ -672,7 +675,7 @@
 	values[8] = Int32GetDatum(srid);
 	values[9] = UInt32GetDatum(numBands);
 	/* build a tuple */
 	tuple = heap_form_tuple(tupdesc, values, nulls);
@@ -683,6 +686,9 @@
 	PG_RETURN_DATUM(result);
 PG_FUNCTION_INFO_V1(RASTER_rasterToWorldCoord);
 Datum RASTER_rasterToWorldCoord(PG_FUNCTION_ARGS)
@@ -694,9 +700,8 @@
 	double cw[2] = {0};
 	TupleDesc tupdesc;
 	HeapTuple tuple;
 	Datum result;
@@ -767,7 +772,7 @@
 	values[0] = Float8GetDatum(cw[0]);
 	values[1] = Float8GetDatum(cw[1]);
 	/* build a tuple */
@@ -790,9 +795,8 @@
 	bool skewed = false;
 	TupleDesc tupdesc;
 	HeapTuple tuple;
 	Datum result;
@@ -868,7 +872,7 @@
 	values[0] = Int32GetDatum(cr[0]);
 	values[1] = Int32GetDatum(cr[1]);
 	/* build a tuple */
Modified: trunk/raster/rt_pg/rtpg_statistics.c
--- trunk/raster/rt_pg/rtpg_statistics.c	2018-09-13 17:25:17 UTC (rev 16779)
+++ trunk/raster/rt_pg/rtpg_statistics.c	2018-09-13 17:25:51 UTC (rev 16780)
@@ -64,6 +64,8 @@
 Datum RASTER_valueCount(PG_FUNCTION_ARGS);
 Datum RASTER_valueCountCoverage(PG_FUNCTION_ARGS);
  * Get summary stats of a band
@@ -80,9 +82,8 @@
 	rt_bandstats stats = NULL;
 	TupleDesc tupdesc;
 	HeapTuple tuple;
 	Datum result;
@@ -160,7 +161,7 @@
 	BlessTupleDesc(tupdesc);
 	values[0] = Int64GetDatum(stats->count);
 	if (stats->count > 0) {
@@ -224,9 +225,8 @@
 	rt_bandstats rtn = NULL;
 	Datum result;
 	/* tablename is null, return null */
@@ -458,7 +458,7 @@
 	values[0] = Int64GetDatum(rtn->count);
 	if (rtn->count > 0) {
@@ -829,9 +829,8 @@
 	TupleDesc tupdesc;
 	HeapTuple tuple;
 	Datum result;
 	POSTGIS_RT_DEBUG(3, "Starting...");
@@ -878,7 +877,7 @@
 	values[0] = Int64GetDatum(state->stats->count);
 	if (state->stats->count > 0) {
@@ -908,6 +907,9 @@
  * Returns histogram for a band
@@ -1153,15 +1155,14 @@
 		HeapTuple tuple;
 		Datum result;
 		values[0] = Float8GetDatum(hist2[call_cntr].min);
 		values[1] = Float8GetDatum(hist2[call_cntr].max);
@@ -1680,15 +1681,14 @@
 		HeapTuple tuple;
 		Datum result;
 		values[0] = Float8GetDatum(covhist2[call_cntr].min);
 		values[1] = Float8GetDatum(covhist2[call_cntr].max);
@@ -1710,6 +1710,9 @@
  * Returns quantiles for a band
@@ -1932,15 +1935,14 @@
 		HeapTuple tuple;
 		Datum result;
 		values[0] = Float8GetDatum(quant2[call_cntr].quantile);
 		values[1] = Float8GetDatum(quant2[call_cntr].value);
@@ -2359,15 +2361,14 @@
 		HeapTuple tuple;
 		Datum result;
 		values[0] = Float8GetDatum(covquant2[call_cntr].quantile);
 		if (covquant2[call_cntr].has_value)
@@ -2391,6 +2392,9 @@
 /* get counts of values */
 PG_FUNCTION_INFO_V1(RASTER_valueCount);
 Datum RASTER_valueCount(PG_FUNCTION_ARGS) {
@@ -2573,15 +2577,14 @@
 		HeapTuple tuple;
 		Datum result;
 		values[0] = Float8GetDatum(vcnts2[call_cntr].value);
 		values[1] = UInt32GetDatum(vcnts2[call_cntr].count);
@@ -3001,15 +3004,14 @@
 		HeapTuple tuple;
 		Datum result;
 		values[0] = Float8GetDatum(covvcnts2[call_cntr].value);
 		values[1] = UInt32GetDatum(covvcnts2[call_cntr].count);
