[postgis-tickets] [PostGIS] #4178: bessie failures - JSON-C required
PostGIS trac at osgeo.org
Thu Sep 13 14:46:26 PDT 2018
 Reporter:  robe       |      Owner:  robe
     Type:  defect     |     Status:  new
 Priority:  blocker    |  Milestone:  PostGIS 3.0.0
Component:  buildbots  |    Version:  trunk
 Keywords:             |
 Who put a test in tickets that requires JSON-C it should go in a JSON-C
 guarded file
 17:43:47  tickets .. failed (diff expected obtained:
 /home/jenkins/tmp/pgis_reg_720bdb57ecf75e9b3cb7805d07675e99519ced30/test_95_diff)
 17:43:49
 17:43:49 --- tickets_expected   2018-09-13 17:35:01.785971000 +0000
 17:43:49 +++
 /home/jenkins/tmp/pgis_reg_720bdb57ecf75e9b3cb7805d07675e99519ced30/test_95_out
 2018-09-13 17:42:30.207129000 +0000
 17:43:49 @@ -335,6 +335,6 @@
 17:43:49  #4089|LINESTRING Z (1 1 1,3 3 1)
 17:43:49  ERROR:  lwgeom_pointonsurface: GEOS Error: TopologyException:
 Input geom 1 is invalid: Self-intersection
 17:43:49  #4081|f|t
 17:43:49 -ERROR:  The 'coordinates' in GeoJSON polygon are not
 sufficiently nested
 17:43:49 +ERROR:  You need JSON-C for ST_GeomFromGeoJSON
 17:43:49  NOTICE:  table "bug_4144_table" does not exist, skipping
 17:43:49  #4176|t
 17:43:49
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4178>
