[postgis-tickets] [PostGIS] #4179: bessie failure on raster install
PostGIS trac at osgeo.org
Thu Sep 13 14:48:46 PDT 2018
 Reporter:  robe                   |      Owner:  strk
     Type:  defect                 |     Status:  new
 Priority:  blocker                |  Milestone:  PostGIS 3.0.0
Component:  build/upgrade/install  |    Version:  trunk
 Keywords:                         |
 Not sure what's causing this might be a configuration issue on my part.
 17:46:27 PATH is
 /usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin:/usr/local/sbin:/usr/local/bin:/home/jenkins/bin:/usr/local:/usr/local/lib:/usr/local/bin
 17:46:27 Checking for shp2pgsql ... found
 17:46:27 Checking for pgsql2shp ... found
 17:46:27 Checking for raster2pgsql ... found
 17:46:27 TMPDIR is
 /home/jenkins/tmp/pgis_reg_720bdb57ecf75e9b3cb7805d07675e99519ced30
 17:46:27 Creating database 'postgis_reg'
 17:46:28 Preparing db 'postgis_reg' using: CREATE EXTENSION postgis
 17:46:30 Preparing db 'postgis_reg' using: CREATE EXTENSION postgis_raster
 17:46:30 Died at run_test.pl line 1329.
 17:46:30  failed (Error encountered creating EXTENSION POSTGIS_RASTER:
 /home/jenkins/tmp/pgis_reg_720bdb57ecf75e9b3cb7805d07675e99519ced30/regress_log)
 17:46:30
 17:46:30 sh: createlang: not found
 17:46:30 CREATE EXTENSION
 17:46:30 ERROR:  could not load library
 "/usr/local/lib/postgresql/rtpostgis-3.0.so": dlopen
 (/usr/local/lib/postgresql/rtpostgis-3.0.so) failed:
 /usr/local/lib/postgresql/rtpostgis-3.0.so: Undefined symbol
 "lwgeom_is_empty"
 17:46:30
 17:46:30 gmake[2]: *** [Makefile:302: check] Error 1
 17:46:30 gmake[2]: Leaving directory
 '/usr/home/jenkins/workspace/PostGIS_Worker_Run/label/bessie/720bdb57ecf75e9b3cb7805d07675e99519ced30/regress'
 17:46:30 gmake[1]: *** [GNUmakefile:16: check] Error 1
 17:46:30 gmake[1]: Leaving directory
 '/usr/home/jenkins/workspace/PostGIS_Worker_Run/label/bessie/720bdb57ecf75e9b3cb7805d07675e99519ced30'
 17:46:30 *** Error code 2
 17:46:30
 17:46:30 Stop.
 17:46:30 make: stopped in
 17:46:31 Build step 'Execute shell' marked build as failure
 17:46:31 Finished: FAILURE
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4179>
