[postgis-tickets] r16790 - Explicitly call perl executable. Should fix failure on FreeBSD (bessie bots) (missed spot on last commit)
Sandro Santilli strk at kbt.io
Fri Sep 14 07:11:47 PDT 2018
On Thu, Sep 13, 2018 at 02:34:52AM +0000, Regina Obe wrote:
> New Revision: 16790
>  sql/raster_unpackage.sql: Makefile
> -sql/raster_unpackage.sql: ../../utils/create_extension_unpackage.pl
> +sql/raster_unpackage.sql: $(PERL) ../../utils/create_extension_unpackage.pl
>  sql/raster_unpackage.sql: unpackage_raster_if_needed.sql
>  sql/raster_unpackage.sql: $(RASTER_DROP_SCRIPTS) | sql
That's just a target dependency, not a command to run,
so you don't need to include PERL here. I fixed this with r16794
--strk;
