[postgis-tickets] [PostGIS] #4160: CREATE or UPDATE extension fails if layer / topology table exists in the public schema
PostGIS trac at osgeo.org
Fri Sep 14 09:13:30 PDT 2018
public schema
  Reporter:  Algunenano             |      Owner:  strk
      Type:  defect                 |     Status:  closed
  Priority:  medium                 |  Milestone:  PostGIS 2.5.0
 Component:  build/upgrade/install  |    Version:  2.2.x
Resolution:  fixed                  |   Keywords:
Comment (by Raul Marin):
 In [changeset:"16802" 16802]:
 #!CommitTicketReference repository="" revision="16802"
 Use qualified names in topology extension install
 References #4160
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4160#comment:7>
