[postgis-tickets] [PostGIS] #4094: Failure to build with PG 11devel configured --with-llvm
PostGIS trac at osgeo.org
Fri Sep 14 11:38:10 PDT 2018
  Reporter:  Laurenz Albe           |      Owner:  Algunenano
      Type:  patch                  |     Status:  closed
  Priority:  medium                 |  Milestone:  PostGIS PostgreSQL
 Component:  build/upgrade/install  |    Version:  trunk
Resolution:  fixed                  |   Keywords:  LLVM clang
Comment (by pramsey):
 In [changeset:"16803" 16803]:
 #!CommitTicketReference repository="" revision="16803"
 rt_pg: Fix build issue with LVM jit
 References #4094
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4094#comment:4>
