[postgis-tickets] r16808 - ST_AsMVT: Support for Feature ID.
Darafei komzpa at gmail.com
Sun Sep 16 07:42:00 PDT 2018
Author: komzpa
Date: 2018-09-16 07:42:00 -0700 (Sun, 16 Sep 2018)
New Revision: 16808
   trunk/NEWS
   trunk/doc/reference_output.xml
   trunk/postgis/lwgeom_out_mvt.c
   trunk/postgis/mvt.c
   trunk/postgis/mvt.h
   trunk/postgis/postgis.sql.in
   trunk/regress/mvt.sql
   trunk/regress/mvt_expected
Patch by Stepan Kuzmin.
Closes #4128
Closes https://github.com/postgis/postgis/pull/274
Modified: trunk/NEWS
--- trunk/NEWS	2018-09-16 07:13:02 UTC (rev 16807)
+++ trunk/NEWS	2018-09-16 14:42:00 UTC (rev 16808)
@@ -5,6 +5,7 @@
     (Sandro Santilli)
 * New Features *
   - #2902, postgis_geos_noop (Sandro Santilli)
+  - #4128, ST_AsMVT support for Feature ID (Stepan Kuzmin)
 * Enhancements and fixes *
   - #4153, ST_Segmentize now splits segments proportionally (Darafei
     Praliaskouski).
Modified: trunk/doc/reference_output.xml
--- trunk/doc/reference_output.xml	2018-09-16 07:13:02 UTC (rev 16807)
+++ trunk/doc/reference_output.xml	2018-09-16 14:42:00 UTC (rev 16808)
@@ -1453,6 +1453,14 @@
 				<paramdef><type>integer </type> <parameter>extent</parameter></paramdef>
 				<paramdef><type>text </type> <parameter>geom_name</parameter></paramdef>
 			</funcprototype>
+		        <funcprototype>
+                                <funcdef>bytea <function>ST_AsMVT</function></funcdef>
+                                <paramdef><type>anyelement </type> <parameter>row</parameter></paramdef>
+                                <paramdef><type>text </type> <parameter>name</parameter></paramdef>
+                                <paramdef><type>integer </type> <parameter>extent</parameter></paramdef>
+				<paramdef><type>text </type> <parameter>geom_name</parameter></paramdef>
+				<paramdef><type>text </type> <parameter>feature_id_name</parameter></paramdef>
+                        </funcprototype>
 		</funcsynopsis>
 	  </refsynopsisdiv>
@@ -1479,7 +1487,10 @@
 		<para><varname>name</varname> is the name of the Layer. If NULL it will use the string "default".</para>
 		<para><varname>extent</varname> is the tile extent in screen space as defined by the specification. If NULL it will default to 4096.</para>
 		<para><varname>geom_name</varname> is the name of the geometry column in the row data. If NULL it will default to the first found geometry column.</para>
+		<para><varname>feature_id_name</varname> is the name of the Feature ID column in the row data. If NULL Feature ID is not set.</para>
+	    <para>Enhanced: 3.0 - added support for Feature ID.</para>
 	    <para>Enhanced: 2.5.0 - added support parallel query.</para>
 		<para>Availability: 2.4.0</para>
 	  </refsection>
Modified: trunk/postgis/lwgeom_out_mvt.c
--- trunk/postgis/lwgeom_out_mvt.c	2018-09-16 07:13:02 UTC (rev 16807)
+++ trunk/postgis/lwgeom_out_mvt.c	2018-09-16 14:42:00 UTC (rev 16808)
@@ -100,6 +100,8 @@
 		ctx->geom_name = NULL;
 		if (PG_NARGS() > 4 && !PG_ARGISNULL(4))
 			ctx->geom_name = text_to_cstring(PG_GETARG_TEXT_P(4));
+		if (PG_NARGS() > 5 && !PG_ARGISNULL(5))
+			ctx->id_name = text_to_cstring(PG_GETARG_TEXT_P(5));
 		mvt_agg_init_context(ctx);
 	} else {
 		ctx = (mvt_agg_context *) PG_GETARG_POINTER(0);
Modified: trunk/postgis/mvt.c
--- trunk/postgis/mvt.c	2018-09-16 07:13:02 UTC (rev 16807)
+++ trunk/postgis/mvt.c	2018-09-16 14:42:00 UTC (rev 16808)
@@ -626,6 +626,12 @@
 #endif
+static void set_feature_id(mvt_agg_context *ctx, Datum datum)
+	ctx->feature->id = datum;
+	ctx->feature->has_id = true;
 static void parse_values(mvt_agg_context *ctx)
 	uint32_t n_keys = ctx->keys_hash_i;
@@ -717,6 +723,11 @@
 			parse_datum_as_string(ctx, typoid, datum, tags, k);
 			break;
+		if (ctx->id_name != NULL && strcmp(key, ctx->id_name) == 0 && (typoid == INT2OID || typoid == INT4OID || typoid == INT8OID)) {
+			set_feature_id(ctx, datum);
 		ctx->row_columns++;
Modified: trunk/postgis/mvt.h
--- trunk/postgis/mvt.h	2018-09-16 07:13:02 UTC (rev 16807)
+++ trunk/postgis/mvt.h	2018-09-16 14:42:00 UTC (rev 16808)
@@ -59,6 +59,7 @@
 	char *name;
 	uint32_t extent;
+	char *id_name;
 	char *geom_name;
 	uint32_t geom_index;
 	HeapTupleHeader row;
Modified: trunk/postgis/postgis.sql.in
--- trunk/postgis/postgis.sql.in	2018-09-16 07:13:02 UTC (rev 16807)
+++ trunk/postgis/postgis.sql.in	2018-09-16 14:42:00 UTC (rev 16808)
@@ -4514,6 +4514,12 @@
 	AS 'MODULE_PATHNAME', 'pgis_asmvt_transfn'
 	LANGUAGE 'c' IMMUTABLE _PARALLEL;
+-- Availability: 3.0.0
+CREATE OR REPLACE FUNCTION pgis_asmvt_transfn(internal, anyelement, text, int4, text, text)
+	RETURNS internal
+	AS 'MODULE_PATHNAME', 'pgis_asmvt_transfn'
+	LANGUAGE 'c' IMMUTABLE _PARALLEL;
 -- Availability: 2.4.0
 CREATE OR REPLACE FUNCTION pgis_asmvt_finalfn(internal)
 	RETURNS bytea
@@ -4598,6 +4604,21 @@
 	finalfunc = pgis_asmvt_finalfn
+-- Changed: 3.0.0
+CREATE AGGREGATE ST_AsMVT(anyelement, text, int4, text, text)
+	sfunc = pgis_asmvt_transfn,
+	stype = internal,
+#if POSTGIS_PGSQL_VERSION >= 96
+	parallel = safe,
+	serialfunc = pgis_asmvt_serialfn,
+	deserialfunc = pgis_asmvt_deserialfn,
+	combinefunc = pgis_asmvt_combinefn,
+#endif
+	finalfunc = pgis_asmvt_finalfn
 CREATE OR REPLACE FUNCTION ST_AsMVTGeom(geom geometry, bounds box2d, extent int4 default 4096, buffer int4 default 256, clip_geom bool default true)
 	RETURNS geometry
Modified: trunk/regress/mvt.sql
--- trunk/regress/mvt.sql	2018-09-16 07:13:02 UTC (rev 16807)
+++ trunk/regress/mvt.sql	2018-09-16 14:42:00 UTC (rev 16808)
@@ -385,6 +385,11 @@
 			ST_MakeBox2D(ST_Point(0, 0), ST_Point(4096, 4096)), 4096, 0, false) AS geom
 ) AS q;
+-- feature id encoding tests
+SELECT 'FI1', encode(ST_AsMVT(q, 'test', 4096, 'geom', 'c1'), 'base64') FROM (SELECT 1 AS c1, 'abcd'::text AS c2,
+	ST_AsMVTGeom(ST_GeomFromText('POINT(25 17)'),
+		ST_MakeBox2D(ST_Point(0, 0), ST_Point(4096, 4096)), 4096, 0, false) AS geom) AS q;
 -- default values tests
 SELECT 'D1', encode(ST_AsMVT(q, 'test', 4096, 'geom'), 'base64') FROM (SELECT 1 AS c1, 'abcd'::text AS c2,
Modified: trunk/regress/mvt_expected
--- trunk/regress/mvt_expected	2018-09-16 07:13:02 UTC (rev 16807)
+++ trunk/regress/mvt_expected	2018-09-16 14:42:00 UTC (rev 16808)
@@ -85,6 +85,7 @@
 NzJBODE2NTQ0MUQ5NDBERkJBRkQ5RUYyNDA0NzRENjI3MkE4MTY1NDQxKIAgeAI=
 TA15|GkkKBHRlc3QSEBIGAAABAQIAGAEiBAky3j8aAmMxGgJjMhoHY3N0cmluZyIDCgExIhQKEjEyLjIz
 MjM4OTI4MzIyMzIzOSiAIHgC
+FI1|GjEKBHRlc3QSEAgBEgQAAAEBGAEiBAky3j8aAmMxGgJjMiICKAEiBgoEYWJjZCiAIHgC
 D1|Gi8KBHRlc3QSDhIEAAABARgBIgQJMt4/GgJjMRoCYzIiAigBIgYKBGFiY2QogCB4Ag==
 D2|Gi8KBHRlc3QSDhIEAAABARgBIgQJMt4/GgJjMRoCYzIiAigBIgYKBGFiY2QogCB4Ag==
 D3|Gi8KBHRlc3QSDhIEAAABARgBIgQJMt4/GgJjMRoCYzIiAigBIgYKBGFiY2QogCB4Ag==
