[postgis-tickets] [PostGIS] #4128: ST_AsMVT: add feature id support
PostGIS trac at osgeo.org
Sun Sep 16 11:58:49 PDT 2018
  Reporter:  stepankuzmin  |      Owner:  pramsey
      Type:  enhancement   |     Status:  reopened
  Priority:  medium        |  Milestone:  PostGIS 3.0.0
 Component:  postgis       |    Version:
Resolution:                |   Keywords:
Comment (by strk):
 If you have docker installed you can investigate the environment of Dronie
 with:
 docker run -ti --rm \
  docker.kbt.io/postgis/build-test:trisquel2 \
  /bin/bash
 I did, to check protoc version:
 root at c4bdbe9eb096:/# protoc-c --version
 protobuf-c 1.3.0
 libprotoc 3.5.1
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4128#comment:7>
