[postgis-tickets] [PostGIS] #4128: ST_AsMVT: add feature id support
PostGIS trac at osgeo.org
Sun Sep 16 13:29:13 PDT 2018
  Reporter:  stepankuzmin  |      Owner:  pramsey
      Type:  enhancement   |     Status:  reopened
  Priority:  medium        |  Milestone:  PostGIS 3.0.0
 Component:  postgis       |    Version:
Resolution:                |   Keywords:
Comment (by Algunenano):
 The id value is being assigned directly from the datum, which is will
 cause issues such as those crashes. I also see that it doesn't do any
 bound checking (so negative values ca be assigned) which could cause
 issues too.
 I'll try to have it fixed and fully documented (negative or NULL values,
 invalid types, column name not found...) tomorrow.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4128#comment:10>
