[postgis-tickets] r16816 - Replace long tag with short-tag for xref ST_MemSize. Was causing problems with po conversion.
Regina Obe lr at pcorp.us
Sun Sep 16 04:58:36 PDT 2018
Author: robe
Date: 2018-09-16 16:58:35 -0700 (Sun, 16 Sep 2018)
New Revision: 16816
   branches/2.5/doc/po/templates/postgis.xml.pot
   branches/2.5/doc/po/templates/reference_editor.xml.pot
   branches/2.5/doc/reference_editor.xml
Update pots (including getting rid of SVN)
Modified: branches/2.5/doc/po/templates/postgis.xml.pot
--- branches/2.5/doc/po/templates/postgis.xml.pot	2018-09-16 21:52:10 UTC (rev 16815)
+++ branches/2.5/doc/po/templates/postgis.xml.pot	2018-09-16 23:58:35 UTC (rev 16816)
@@ -6,7 +6,7 @@
 msgstr ""
 "Project-Id-Version: PACKAGE VERSION\n"
 "Report-Msgid-Bugs-To: http://bugs.kde.org\n"
-"POT-Creation-Date: 2018-09-16 15:38+0000\n"
+"POT-Creation-Date: 2018-09-16 16:50+0000\n"
 "PO-Revision-Date: YEAR-MO-DA HO:MI+ZONE\n"
 "Last-Translator: FULL NAME <EMAIL at ADDRESS>\n"
 "Language-Team: LANGUAGE <kde-i18n-doc at kde.org>\n"
@@ -20,12 +20,6 @@
 msgid "PostGIS &last_release_version; Manual"
 msgstr ""
-#. Tag: subscript
-#: postgis.xml:128
-#, no-c-format
-msgid "SVN Revision (<emphasis></emphasis>)"
-msgstr ""
 #. Tag: corpauthor
 #: postgis.xml:132
 #, no-c-format
Modified: branches/2.5/doc/po/templates/reference_editor.xml.pot
--- branches/2.5/doc/po/templates/reference_editor.xml.pot	2018-09-16 21:52:10 UTC (rev 16815)
+++ branches/2.5/doc/po/templates/reference_editor.xml.pot	2018-09-16 23:58:35 UTC (rev 16816)
@@ -6,7 +6,7 @@
 msgstr ""
+"POT-Creation-Date: 2018-09-16 20:04+0000\n"
Modified: branches/2.5/doc/reference_editor.xml
--- branches/2.5/doc/reference_editor.xml	2018-09-16 21:52:10 UTC (rev 16815)
+++ branches/2.5/doc/reference_editor.xml	2018-09-16 23:58:35 UTC (rev 16816)
@@ -1179,7 +1179,7 @@
 			<note>
 				<para>
 					Only the on-disk size of the geometry is potentially affected by
-					<code>ST_QuantizeCoordinates</code>.  <xref linkend="ST_MemSize"></xref>,
+					<code>ST_QuantizeCoordinates</code>.  <xref linkend="ST_MemSize" />,
 					which reports the in-memory usage of the geometry, will return the
 					the same value regardless of the disk space used by a geometry.
 				</para>
