[postgis-tickets] r16819 - Fix parse errors in po files. Update ChangeLog in prep for release
Regina Obe lr at pcorp.us
Sun Sep 16 07:44:34 PDT 2018
Author: robe
Date: 2018-09-16 19:44:34 -0700 (Sun, 16 Sep 2018)
New Revision: 16819
   branches/2.5/ChangeLog
   branches/2.5/doc/po/es/extras_topology.xml.po
   branches/2.5/doc/po/ko_KR/reference_raster.xml.po
Modified: branches/2.5/ChangeLog
--- branches/2.5/ChangeLog	2018-09-17 02:29:47 UTC (rev 16818)
+++ branches/2.5/ChangeLog	2018-09-17 02:44:34 UTC (rev 16819)
@@ -1,3 +1,154 @@
+2018-09-16 23:58  Regina Obe <lr at pcorp.us>
+	* [r16816] Replace long tag with short-tag for xref ST_MemSize. Was
+	  causing problems with po conversion.
+	  Update pots (including getting rid of SVN)
+2018-09-16 21:52  Regina Obe <lr at pcorp.us>
+	* [r16815] Prepping for 2.5.0 release
+2018-09-16 21:36  Regina Obe <lr at pcorp.us>
+	* [r16814] Move geofromjson test from tickets to in_geojson so
+	  JSON-C guard can be applied.
+	  Closes #4178 for PostGIS 2.5.0
+2018-09-16 20:24  Regina Obe <lr at pcorp.us>
+	* [r16813] Try to force liblwgeom source include to be referenced
+	  first before the installed locations.
+	  When installed, the installed one sometimes gets picked up
+	  instead of the source one.
+	  References #4180
+2018-09-16 18:51  Regina Obe <lr at pcorp.us>
+	* [r16811] remove de_DE, it's redundant with de which is more
+	  complete.
+	  Update all the po files (pulled from transifex)
+	  References #3848
+2018-09-16 16:18  Regina Obe <lr at pcorp.us>
+	* [r16809] Update pot files
+2018-09-16 05:12  Regina Obe <lr at pcorp.us>
+	* [r16806] Document that LLV >= 6 is required for JIT compiles.
+	  Closes #4125 for PostGIS 2.5.0
+2018-09-14 16:13  Raúl Marín Rodríguez <rmrodriguez at carto.com>
+	* [r16802] Use qualified names in topology extension install
+	  References #4160
+2018-09-13 20:28  Paul Ramsey <pramsey at cleverelephant.ca>
+	* [r16786] Handle almost-infinite features when building table
+	  statistics in ANALYZE
+	  References #4144
+2018-09-13 19:25  Paul Ramsey <pramsey at cleverelephant.ca>
+	* [r16784] Avoid array overflow in ANALYZE (References #2985)
+2018-09-13 17:25  Darafei Praliaskouski <me at komzpa.net>
+	* [r16779] Postgres 12 disallows variable length arrays in C,
+	  raster part
+	  Patch by Laurenz Albe
+	  Closes #4177
+2018-09-13 14:57  Darafei Praliaskouski <me at komzpa.net>
+	* [r16778] Postgres 12 disallows variable length arrays in C
+	  Closes #4177
+2018-09-13 13:29  Darafei Praliaskouski <me at komzpa.net>
+	* [r16773] ST_Interscts support GEOMETRYCOLLECTION
+	  By some overlook ST_Intersects has a guard against
+	  GEOMETRYCOLLECTION, while GEOS can handle it.
+	  Closes #4176
+	  Closes https://github.com/postgis/postgis/pull/297
+2018-09-13 13:25  Darafei Praliaskouski <me at komzpa.net>
+	* [r16772] Add NEWS entry.
+	  References #4164
+2018-09-11 06:07  Regina Obe <lr at pcorp.us>
+	* [r16728] Get rid of note that 3.7.0 is not released. Switch
+	  winnie to test and packaged released 3.7.0
+2018-09-10 22:27  Paul Ramsey <pramsey at cleverelephant.ca>
+	* [r16726] NL warning and add regression test
+	  References #4164
+2018-09-10 22:18  Paul Ramsey <pramsey at cleverelephant.ca>
+	* [r16724] Parse error on incorrectly nested GeoJSON input
+	  References #4164
+2018-09-07 10:57  Raúl Marín Rodríguez <rmrodriguez at carto.com>
+	* [r16721] Fix memory leak in lwgeom_offsetcurve
+	  References #4172
+2018-09-06 20:17  Paul Ramsey <pramsey at cleverelephant.ca>
+	* [r16716] Increase double printing buffer, and strip out assertion
+	  that buffer is never filled
+	  (References #4165)
+2018-08-29 09:28  Raúl Marín Rodríguez <rmrodriguez at carto.com>
+	* [r16709] MVT: Fix resource leak when the first geometry is NULL
+	  References #4163
+2018-08-28 07:51  Darafei Praliaskouski <me at komzpa.net>
+	* [r16707] Clarify ST_DWithin usage when table stores a point and a
+	  radius.
+	  Added after IRC discussion.
+	  Thanks github user Boscop for questions and review.
+	  Closes #4162
+	  Closes https://github.com/postgis/postgis/pull/289
+2018-08-28 07:25  Regina Obe <lr at pcorp.us>
+	* [r16705] Move ST_QuantizeCoordinates from miscellaneous to
+	  Editors and fix the first example
+2018-08-19 22:16  Regina Obe <lr at pcorp.us>
+	* [r16700] update translation files, bump version to 2.5.0rc2dev,
+	  update badges
+2018-08-19 21:41  Regina Obe <lr at pcorp.us>
+	* [r16698] Branch 2.5
+2018-08-19 15:09  Regina Obe <lr at pcorp.us>
+	* [r16696] Update change log in prep for 2.5.0rc1 release
 2018-08-19 14:02  Regina Obe <lr at pcorp.us>
 	* [r16695] put in date
Modified: branches/2.5/doc/po/es/extras_topology.xml.po
--- branches/2.5/doc/po/es/extras_topology.xml.po	2018-09-17 02:29:47 UTC (rev 16818)
+++ branches/2.5/doc/po/es/extras_topology.xml.po	2018-09-17 02:44:34 UTC (rev 16819)
@@ -139,7 +139,7 @@
 msgstr ""
 "El soporte de Topology se compila por defecto comenzando con PostGIS 2.0, y "
 "puede ser deshabilitado especificando --without-topology configure la opción "
-"en tiempo de compilación como se describe en < xref linkend = "
+"en tiempo de compilación como se describe en <xref linkend = "
 "\"postgis_installation\"/>"
 #. Tag: para
Modified: branches/2.5/doc/po/ko_KR/reference_raster.xml.po
--- branches/2.5/doc/po/ko_KR/reference_raster.xml.po	2018-09-17 02:29:47 UTC (rev 16818)
+++ branches/2.5/doc/po/ko_KR/reference_raster.xml.po	2018-09-17 02:44:34 UTC (rev 16819)
@@ -16614,9 +16614,9 @@
 #: reference_raster.xml:6937
 #, no-c-format
 msgid ""
-"<refpurpose>Returns a raster or a set of geometry-pixelvalue pairs "
+"Returns a raster or a set of geometry-pixelvalue pairs "
 "representing the shared portion of two rasters or the geometrical "
-"intersection of a vectorization of the raster and a geometry.</refpurpose>"
+"intersection of a vectorization of the raster and a geometry."
 msgstr ""
 "두 래스터의 공유 부분을 표현하는, 또는 벡터화된 래스터와 도형의 기하학적 교차"
 "를 표현하는 래스터 또는 도형-픽셀값 쌍의 집합을 반환합니다."
@@ -23558,7 +23558,7 @@
 "if the bounding box of raster/geometr A intersects the bounding box of "
 "raster/geometr B."
 msgstr ""
-"<varname>&&</varname> 연산자는 래스터/도형 A의 경계 상자와 래스터/도형 B의 경"
+"<varname>&&</varname> 연산자는 래스터/도형 A의 경계 상자와 래스터/도형 B의 경"
 "계 상자가 교차하는 경우 <varname>TRUE</varname> 를 반환합니다."
 #. Tag: para
@@ -23633,7 +23633,7 @@
 "of raster B, or more accurately, overlaps or is NOT to the right of the "
 "bounding box of raster B."
 msgstr ""
-"<varname>&<</varname> 연산자는 래스터 A의 경계 상자가 래스터 B의 경계 상자와 "
+"<varname>&<</varname> 연산자는 래스터 A의 경계 상자가 래스터 B의 경계 상자와 "
 "겹치거나 그 왼쪽에 있을 경우, 또는 더 정확히 말하자면 래스터 B의 경계 상자와 "
 "겹치거나 그 오른쪽에 있지 않을 경우, <varname>TRUE</varname> 를 반환합니다."
@@ -23707,7 +23707,7 @@
 "of raster B, or more accurately, overlaps or is NOT to the left of the "
 msgstr ""
-"<varname>&></varname> 연산자는 래스터 A의 경계 상자가 래스터 B의 경계 상자와 "
+"<varname>&></varname> 연산자는 래스터 A의 경계 상자가 래스터 B의 경계 상자와 "
 "겹치거나 그 오른쪽에 있을 경우, 또는 더 정확히 말하자면 래스터 B의 경계 상자"
 "와 겹치거나 그 왼쪽에 있지 않을 경우, <varname>TRUE</varname> 를 반환합니다."
@@ -23795,7 +23795,7 @@
 msgstr ""
 "<varname>=</varname> 연산자는 래스터 A의 경계 상자와 래스터 B의 경계 상자가 "
 "동일할 경우 <varname>TRUE</varname> 를 반환합니다. PostgreSQL은 래스터를 내"
-"부 정렬하고 비교하기 위해 도형에 대해 정의된 =, <, 및 > 연산자를 이용합니다"
+"부 정렬하고 비교하기 위해 도형에 대해 정의된 =, <, 및 > 연산자를 이용합니다"
 "(예: GROUP BY 또는 ORDER BY 절에서)."
 #. Tag: para
