[postgis-tickets] [PostGIS] #4183: Invalid output of ST_ClipByBox2D with an invalid polygon
PostGIS trac at osgeo.org
Wed Sep 19 09:40:03 PDT 2018
 Reporter:  Algunenano  |      Owner:  Algunenano
     Type:  defect      |     Status:  assigned
 Priority:  medium      |  Milestone:  PostGIS GEOS
Component:  postgis     |    Version:  trunk
 Keywords:              |
 I start with a valid polygon:
 Select St_IsValid('SRID=3857;MULTIPOLYGON(((-8231365.02893734
 4980355.83678553,-8231366.94866817 4980350.2976052,-8231368.82883367
 4980344.52250402,-8231370.96255986 4980333.47364302,-8231372.09200747
 4980327.69798564,-8231372.84505222 4980323.68014243,-8231374.2255656
 4980316.77455645,-8231375.10554947 4980309.86865218,-8231380.6311111
 4980275.9676398,-8231394.82332406 4980186.31880185,-8231394.8569833
 4980133.57928934,-8231367.43081065 4979982.17443372,-8231372.85765532
 4979985.17751813,-8231395.25669799 4980132.93828551,-8231396.69199339
 4980227.59327083,-8231377.30092207 4980340.77515211,-8231368.35061694
 4980357.62467295,-8231365.02893734 4980355.83678553)))'::geometry);
  st_isvalid
  t
 I pass this polygon through `ST_Simplify and ST_RemoveRepeatedPoints` and
 it comes up as invalid:
 Select
 St_IsValid(ST_Simplify(ST_RemoveRepeatedPoints('SRID=3857;MULTIPOL...'),
 19.109257221221924), 19.109257221221924, true));
  st_isvalid
  f
 (1 row)
 Then I pass it through ST_ClipByBox2D:
 Select St_AsEWKT(ST_ClipByBox2D(
     'MULTIPOLYGON(((-8231365.02893734 4980355.83678553,-8231394.82332406
 4980186.31880185,-8231367.43081065 4979982.17443372,-8231396.69199339
 4980227.59327083,-8231365.02893734 4980355.83678553)))'::geometry,
     'POLYGON((-8228215.28157305 4980103.20610541,-8228215.28157305
 4970163.3879457,-8238155.09973276 4970163.3879457,-8238155.09973276
 4980103.20610541,-8228215.28157305 4980103.20610541))'::geometry
 POLYGON((-8238155.09973276 4970163.3879457,-8238155.09973276
 4980103.20610541,-8231383.67109061 4980103.20610541,-8231367.43081065
 4979982
 .17443372,-8231381.86136498 4980103.20610541,-8228215.28157305
 4980103.20610541,-8228215.28157305 4970163.3879457,-8238155.09973276
 4970163
 .3879457))
 The result seen is not the intersection (as expected) but the result of
 subtracting the geometry area to the box.
 In truth this series of chained calls come from St_AsMVTGeom where this
 functions are called inside the same C function, but seeing the individual
 calls makes it easier to spot the issue.
 I've traced this behaviour back to GEOS
 (https://github.com/Algunenano/geos/commit/1737fa1a34e6cc30fb26b2898f607d5db3b176a6).
 Does anyone know if GEOSClipByRect is supposed to handle invalid
 geometries correctly or to just give an invalid output as the one seen
 above?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4183>
