[postgis-tickets] [PostGIS] #4156: ST_ChaikinSmoothing not treating inner and outer rings the same
PostGIS trac at osgeo.org
Fri Sep 21 06:20:51 PDT 2018
  Reporter:  komzpa   |      Owner:  nicklas
      Type:  defect   |     Status:  closed
  Priority:  medium   |  Milestone:  PostGIS 3.0.0
 Component:  postgis  |    Version:  trunk
Resolution:  fixed    |   Keywords:
Comment (by komzpa):
 In [changeset:"16828" 16828]:
 #!CommitTicketReference repository="" revision="16828"
 ST_ChaikinSmoothing: also smooth start/end point of polygon by default
 Closes #4156
 Closes https://github.com/postgis/postgis/pull/305
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4156#comment:10>
